Thermador DW246US is "stuck" in the last drain cycle. It wont stop and restart. Have tried resetting, using the Heave and Light Wash buttons. Any ideas?
  • 21 Answers
SOURCE: Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Posted on Dec 29, 2008
  • 1294 Answers
SOURCE: controls locked button on and other cycles light
Power shd be on. Press the "end of cycle" button on the right side for 3 seconds.
Posted on Mar 19, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
  • 713 Answers
SOURCE: water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Posted on Apr 09, 2010
  • 43501 Answers
SOURCE: washer wont drain. fills
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Posted on Apr 21, 2011
Wash started cycle. Wife stopped it at beginning of cycle. Now washer will not start at at. Lid switch is good. Will not spin, rinse, restart wash, nothing, not even clicking.
Does unit have a reset button? If it has manual control for cycle did you try going clockwise to the start position and then restarting?
If she stopped the cycle by opening the door perhaps that switch is still stuck in an open position.
Aug 31, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine stops during wash cycle full of water
object stuck in pump, drain water remove and clean pump re start
Dec 09, 2013 | Washing Machines
Do you have any insight into disassembly of a thermador DW246US dishwasher?
Hi, Welcome to FixYa. Since this model Thermador is a B/S/H/ built ( bosch...provided the model is indeed DW246US ) machine let me know what you want to service and I can provide pretty much any service guides, info and direction on what or how to proceed. Macmarkus :)
Oct 09, 2010 | Thermador DW44Z Built-in Dishwasher
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Dishwasher not completing the programed wash, Now won't restart.
There is not a reset button, but you can try by holding both drain and one of the wash cycle.. hold it for a few seconds.. keeping trying drain and another, and another.... you will hear drain motor draining water out... if there is standing water at the bottom... if the cycle stopped after wash cycle, its usually your control... hope this help...
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishwasher does not drain water
I had the same problem after a year of use. All the cycle sounded good except for the drain. I disconnected the drain hose with all turned off and only a small amount of water came out ( the inside pan was full ) I then stuck it to my mouth ( gross ) and nothing but back pressure. Another great heave and POW a wad of grease came out. In short by wife poured some fresh stock down the drain which backed into the drain pipe and cooled. Done.
Jul 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
