Question about Samsung Refrigerators
Ice bucket on Samsung RF31FMESBSR will not come out. It is fully defrosted and will not move. It is about a 1/2 inch out and stuck. I read this may be due to the ice maker falling into the tray
SOURCE: ice tray stuck
Hi My Samsung freezer was nor a RB2155 it is a RS2630SH however after not making any ice because the tray was stuck in the upside down position or thereabout after 6 weeks it suddenly started making ice again, we had not done anything to it but we heard it dropping ice one evening and we had a look in the ice container and low and behold the ice box was full to the top, I would still like to know why it went like that in the first place in case it happens again it is a mystery. Larry
Posted on Dec 23, 2006
HVACRH20
  • 237 Answers
SOURCE: Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Posted on Dec 31, 2006
SOURCE: Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Posted on Apr 18, 2008
  • 145 Answers
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
SOURCE: Samsung RS2555SL Ice Maker gone nutty!
The icemaker relies on the motor to twist the ice tray about 120 degrees or so the dump the ice out of the tray. In order to get the ice to separate from the tray the force of the motor actually torques the tray against the rear plastic support (much like you would twist an old fashioned ice tray that you fill up by hand). Anyway, this puts a lot of force on the plastic elements that support the tray and they break after time. Once the plastic support breaks in the back there is nothing to get the ice out of the tray and each subsequent filling of the ice tray results in water spilling all over the ice bin and eventually leaking out the front of the refrigerator. You can order the part and fix it yourself (the part is DA61-00244A and is available from a number of websites. Total cost about $16 with shipping.
Posted on Nov 04, 2009
I can pull the ice bucket out about an inch then stuck..???
You have ice stuck inside where it has dispensed but it apparently did not drop all the way down to the container. Only thing you can do is shake it until everything drops, allowing the bin to be removed.
Dec 07, 2017 | Samsung Refrigerators
Cannot get the ice bucket out.
Take a hair blower and defrost it
Dec 31, 2015 | Refrigerators
Why is ice bucket stuck?
One of 2 things happened. Your ice maker overflowed with water and now the bucket is frozen or the ice maker fell into the bucket and it's wedged. If you can get the bucket out at least a inch it's the second problem
Oct 01, 2015 | Samsung Refrigerators
How to release jammed ice maker bucket
you have ice stuck in it . best thing to do so you dont damage it is to defrost it/remove/clean .
Jan 23, 2015 | Refrigerators
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Water and ice maker not working line frozen everything frozen even when you turn it down is it the termostat or what
It sounds like your ICE Dispenser door is stuck partway open. Defrost the access door, ice bucket and crusher then check the Ice Dispenser door to be sure it fully closes, otherwise cold air will constantly drift out and freeze the whole mechanism.
Mar 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an U-line combo 75A and the ice maker(part number 400) has started overfilling. When water enters the ice maker, it runs out the overflow hole. Any suggestions?
few thing can happen, bad thermostat it caused the ice maker stuck in harvest cycle, short in ice maker defrost heater, bad water valve switch or the overflow hole drilled to low, it should be 1/4 inch below the top, I seen some of them drilled 1/2 inch below and it caused water leak.
Feb 24, 2010 | U-Line Uline Origins Series...
Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position.  If it doesn't want to move don't force it.  Try shutting the ice maker off in case the arm is frozen in the up position.  After the ice maker defrosts a bit try again to move the arm gently.
May 29, 2009 | Samsung RF265AA Bottom Freezer French Door...
Ice maker only operates on crushed ice mode
There should be a solenoid behind the ice bucket that moves an metal arm on the ice bucket to move the crush teeth away for cubes or keeps the crush teeth in place for crushed cubes. Bad solenoid, bad wire at the solenoid, broken solenoid/mechanism piece, bent arm, no power from dispenser to the solenoid are -some- possible trouble makers.
Also the solenoid that controls the crush/cube function is probably frozen. First, pull out your ice bucket. On the bottom of the bucket is a long metal rod the runs all the way to the back wall of the freezer. That rod runs into a little square hole in the back of the freezer. The hole is about 1 and half inches square. Just put your finger in there and see if the solenoid plunger moves up and down easily. If it doesn't move, then it is frozen. Just hit that area with a hair dryer and it will release. If it moves easily, then make sure that the the rod on the ice bucket is seated in there properly
Feb 09, 2009 | Kenmore Refrigerators
Refrigerators Logo
52 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
