Question about Konica Minolta bizhub 200 Printer
Bizhub 200 erro code c3452 - Konica Minolta bizhub 200 Printer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Its related to Fuser Unit,
Try to reset by Switch On Main Power switch by holding Utility Button for 10-15 second.
Troublereset Option will appear
touch it
switch off again and on in normal way.
Posted on Jan 05, 2017
How to rest a C3452 error code on a minolta C300
try a trouble reset turn the machine off hold utility/counter power machine on select trouble reset reboot machine
Aug 17, 2014 | Konica Minolta Bizhub C300 All-In-One...
How do i solve error code c3452 for bizhub konika minolta
remove the network cable, right next to the network connection is a cover remove it. there is a small black button, using a pen push it then watch the control panel it will goes thought certain screen watch for one with a small . in the center on the left side when you see it press the "3". let it go to the code. Then press the counter switch, will see a new icon "Maintenance Mode" press it the press trouble reset. let the machine go though screen again this time let it go to ready to copy if the code come back replace the fuser unit the HOT part, do not reset again you messing with the fuser which can catch on fire, that will ruin a perfectly good day
Jun 04, 2014 | Konica Minolta bizhub 200 Printer
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Error c3452
error c3452 is fusing warm-up failure.
first do trouble reset.
second, check H1 or H2
third, check TH1 and TH2
four, change new fusing unit
five, change PU
six, change PWB-A
Sep 14, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Jul 23, 2013 | Minolta bizhub 200 All-In-One Printer
Bizhub 200 has error code c3452
Sir/mam check the right side door that you open to remove the image unit check that the two latches that hold the door close are OK especially the rear one. Close up. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover with the machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!!
Jan 23, 2012 | Minolta bizhub 200 Copier
How and where to solve /fix error code C-D301 on bixhub c250
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Dec 06, 2011 | Konica Minolta bizhub C250 All-In-One...
C3452
hi ali... the problem with your mfp is fixing uunit warm up failure... try to perform trouble reset... turn off the machine, then hold press the utility/ counter... konica minolta logo appears... press 3, type eight 0's then then tuoch "end" then touch "trouble reset"( note: dont touch other menu displayed on screen because you might get another problem.) then the machine will re-statr.....If there is an abort code, there its time for you to change the fixing unit.... ( if you know electronics try to check the heater lamp and thermostat using a multitester, check if there is a continuity inthe both ends...)
Apr 29, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
When I turn on the machine (bizhub c300) error code c3452 appears, within 20 secs, How do I reset this code
This is a fuser related code.
To reset the code, please do the following
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch Trouble Reset.
4. Check to make sure that OK is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Good luck
Jan 21, 2010 | Konica Minolta Bizhub C300 All-In-One...
IT KEEPS DISPLAYING ERRO C3452 ONLY. THAT ERROR IS DETECTED BY THE MACHINE I SHOULD PLS CONTACT MY TECHNICIAN.
this is a low fuser temerature code you can reset it by the following method:
1. on the right side of the machine there is a small cover you can remove next to the network card it just clips on pull down on the small lever and pull it down
2. once the cover is removed you will see a connector and a small hole with a switch in it to the right of the connector push the switch with a small object like a ball point pen.
3.when a small dot appears on the touchscreen hit the number 3 on the number pad.
4.enter the 8 digit service code which is 00000000 and touch end.
5. select trouble reset to reset the error code.
if the error code reccurs you will need to replace the fuser unit but i have seen the machines show this error when they are turned on while the room temp is cold first thing in the morning.
Nov 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 200 Printer Logo
93 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
