Skyrover rolls hard right on take off, can't counter it. Any way to fix it?
The left ear is louder and much clearer than the right ear
Tried the knife, made it 10% better but no wax to clean, bc a small rubber circle is under the net... 3 good hard plucks made mine work again. Don't be afraid to pluck it hard, I tried it before softer, which didn't work initially. Reassemble, twist it's neck counter clockwise (right ear) and pluck HARD.
Feb 11, 2014 | Motorola Mobility S11-HD Bluetooth...
I have a 2006 Nissan Altima. It has been having a hard time rolling over when starting. The digital indicator light by the mileage shows an "A" with a box around it. I checked for this indicator li
hey ashley. the "A" symbol is just a mileage counter. i have an altima aswell and we can cycle thru A, B, C for mileage counters, km til empty for gas, the time, temperature outside, and total driving time. cycle tbru by hitting the mode button on the left of the steering wheel buttons, right beside the seek for songs buttons
Apr 11, 2013 | 2006 Nissan Altima
Galaxy 2517dx freaq counter rolls between present channel and the next channel or so some times. and when it does that it acually goes to that channel. it dose it especially when you change to certain...
You radio is Oscillating. For most things I can give an at home fix. But from what you are saying you should take it to a tech and have them put it on a Oscilloscope. The frequencies are not mixing right. Anymore questions feel free to ask.
Feb 01, 2011 | Galaxy Radios DX-2517 CB Radio
The frame counter is set on S, the film advance lever doesn't work anymore either. Is there anything I can do or should i take it to get fixed?
frame counter,mechanism is bad,before u get it fixed,try urself open the back door of the film chamber u will find a lever just below the number counter,move it freely ,push and leave, the put a dummy roll and move forward the film,if u get number counter working ok
Mar 05, 2010 | Vivitar V4000 50MM 35mm SLR Camera
Rolling Frequency Counter
I'm giving this info from the Master Edition of C.B. Tune-up manual Volume 1 year -1995. The original price of this info was $39.95 But I have had people help me with radio info. so here it is---- on page 60 it says [ Model ] : Galaxy Saturn ( and export models using the same Freq. counter module ) The most common problem with the { Galaxy Saturn } is after it has been on for awhile the read-out becomes unstable. And sometimes it will quit all together. This problem has been traced to a Zener Diode inside the freq, counter module. The square silver box located right behind the speaker. The Zener Diode inside marked D-603. This is a 2.4 volt , 1/4 watt diode next to IC-609 the ( LM-7808 ) regulator. REMEDY: change D-603 to a ( 2.4 volt , 1/2 watt diode) This should restore normal operation. {{{{ 357 - MAVERICK }}}
Mar 13, 2009 | Galaxy Radios DX-2517 CB Radio
Mamiya M645j film counter not advancing to start when roll loaded
It's a common problem in the 645 - if you want to do it yourself, without a permanent fix, put a DROP ( not a lot ) of lighter fluid, or rubbing alcohol on the tip of a fine screwdriver and apply it to the gear you use to rewind the camera, and turn back and forth a few times. If that doesn't loosen it, it'll have to be disassembled.
Jan 07, 2009 | Mamiya 645 Medium Format Camera
Rear Passenger window won't roll up
No the only way to fix these wire regulators is replace them, they are fairly cheap, think about it, you pull the door panel, remove the regulator try to fix it and put it back, right away it fouls up, you have worked hard for nothing, replace it.
Aug 15, 2008 | 1992 Honda Accord
Need to get the meter count on my canon 6545 copier
The meter is located on the inside left hand side right above the fixing unit.. That is called the hard counter. There is also electronic counter that can be seen in service mode, but they can be reset at any time.
Apr 25, 2008 | Canon NP 6545 Copier
jasbo
jasbo
