HI I HAVE A 32 INCH CELLO HD LED TV AND ITS GOES OF AFTER A FEW MINS JUST SOUND AND THE REMOTE WONT WORK AND THE BUTTONS ON THE TV WONT WORK HAVE TO TURN OF AT THE WALL
  • 31 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Posted on Oct 26, 2008
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 718 Answers
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
Posted on Apr 24, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
Sound is pinned at 100% output. Remote nor physical buttons on device are working.
If any of the buttons on the remote or tv work, then try going into the menu and turning the sound down manually.
Jan 08, 2017 | Televison & Video
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
Mar 05, 2015 | LG 22LV2500 22" Inch 720p Widescreen LED...
We have a 32" HD LED LCD TV (Model BVALED32). We can turn it on using button on tv, remote does not seem to work. The only thing we get is the GVA logo screen and we cannot get movie to play anymore
Try unplugging the TV for a few minutes and then plug it back in. change the batteries on the remote, too. I can't say this will work for sure. IF that does not work, you need to take it in for repair or call customer report for help.
Nov 13, 2014 | Televison & Video
HI, MY NAME IS S. A. ANSARI, I HAVE A SHARP AQUOS LC-32A66M LCD TV. ONE DAY SUDDENLY GOES INTO STAND BY MODE. NOW WHENEVER WE TRIED TO TURNED IT ON, IT ON FOR 30 SECOND I.E. WE CAN SEE PICTURE, HEAR SOUND...
Hi Ansari
It sounds like a main board problem. The control voltage that goes to back-light inverter board; from the main board, goes down. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Feb 27, 2014 | Sharp LC-32A66M 32 inch Multi-System Full...
My universal remote wont work on my cello tv
Does the TV work with its supplied remote, could the problem be the TV? How are the batteries in the remote, are they in correctly, try new ones. You can usually see the LED on the remote light up when you press a button by looking at it through a digital camera's viewfinder. Not all universal remotes will work with all TV's, is your TV listed as compatible in the remote's instructions? Does the remote have a customer support number?
Jan 07, 2013 | Televison & Video
I need a 4 didit code for my remote for my neon telly
Neon are a brand made by Cello.
This is from their FAQ page here
http://www.celloelectronics.com/faqs#
"There are no codes available for the Sky remote controls, however due to a high demand from customer’s Cello have been working on a new remote control design which will be supplied with the latest range of TV’s as well as being available to purchase from Contrast Technology. This modern design will work with all 73 and 51 series LCD TV’s that use the RC08 and 09 remote handset and will operate the following satellite boxes:
  • Sky Digital
  • Sky Plus
  • Sky HD Plus"
Apr 18, 2010 | Televison & Video
Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card, Lets first make sure your remote is not causing your problem, Look at the light (led) on the remote, is it lit and pulsing? If not you are having a problem with the control panel,  Have you recently cleaned your tv with a liquid? If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it.  Let me know if this helps and please rate this solution.   lone99star
Jan 11, 2009 | Soyo DYLT032D 32 in. LCD Television
TV goes black, won't power off
If the power indicator remains on (or LED remains green) when the unit goes dead, you will need to replace the main board to resolve.
Dec 22, 2008 | Vizio L32 32 in. LCD HDTV
32 Philips hd flat screen #32pf7320a/37b on for a time,then black
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
Dec 15, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
We have thomson tv 32" color crt sort length model 29df45 c s /icc20
tv power goes off when vcd / dish receiver is connected
Aug 12, 2008 | Thomson 29DM400 29" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
