Question about Keurig Coffee Makers & Espresso Machines
Can I increase temperature output of Keurig coffee maker ?
SOURCE: I cannot get a full cup of coffee from my Keurig
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
Posted on Jun 14, 2009
cmccune04
  • 213 Answers
SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 13, 2010
cmccune04
  • 213 Answers
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
Posted on Apr 14, 2010
espressonist
  • 1711 Answers
SOURCE: my keurig coffee maker turns its self off, even
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
  • 40 Answers
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
My coffee from my keurig is too hot
Coffee is mostly water, so can't pass over 100?C. All coffee makers work under the principle of boiling the water and pass the steam through the grinded coffee
If you wait some time, it cools off to a confortable temperature to drink.
Just guess you wanted to ask something else. In some coffee makers you should not use coffee grinded too fine or should not compact the coffee because it get's "explosive"
Oct 24, 2015 | Keurig Coffee Makers & Espresso Machines
Coffee not hot
It is factory set and you have no manual control to override the settings.
Sep 18, 2012 | Keurig Special Edition B60 Coffee Maker
Output from Keurig Elite B40 appears to be only 4oz for a cup and 8 oz for a mug, how can this be adjusted?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Mar 02, 2011 | Keurig Elite B40 Coffee Maker
What should the ideal temperature be for the coffee?
According to the SCAA, the optimal water temperature for brewing coffee is 92 - 96C (197.6 - 204.8F) for 90% of the contact time.
That's too hot to drink, since the human tongue can only stand about 140 degrees F.
Charlie
Jan 11, 2011 | Keurig Platinum B70 Coffee Maker
The coffee maker is only brewing 1/4 cup of coffee
Descale you brewer and that will increase your cup size to what it should be
Mar 14, 2010 | Keurig Platinum B70 Coffee Maker
Weak coffee
Have you de-scaled and rinsed your Keurig?
Two things more you should look after: Boiling temperature and cleaning the funnel and exit needle.
Instructions here:
http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Nov 24, 2008 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
