Question about Amazon Fire TV Stick
New firestick worked out of the box but then quit. The menu runs across the top instead of down the side like it did out of the box. Tried evrerything mentioned on troubleshooting but no luck.
I downloaded kodi on my FireStick but it won't install it, how can i fix it
Hey, there are couple of ways to download as well as installing Kodi on Firestick. I am not sure which method you used to download Kodi. I would suggest you download Kodi using ES File Explorer and then it will show install button as soon as download completes.
You can also check this guide - https://www.firesticktricks.com/install-kodi-on-fire-stick.html
If any further issues, please let me know.
Mar 06, 2017 | Televison & Video
I have a Sony tv that I have my new firestick attached to currently. But my xfinity x-1 box is plugged into my marantz system where my speakers are connected and controlled.
You should have an optical audio output jack on your tv that you can connect to your receiver to output audio through your speaker system.
Dec 26, 2015 | Sony Audio Players & Recorders
How to activate PBS using Amazon Firestick on my Tablet?
Just opened with this URL: http://www.pbs.org/activate
Enter the code in the box that says Activation Code, and hit continue.
Mar 29, 2015 | Amazon Tablets & eReaders
Need to mo we an electrical power point in a brick wall in my apartment
More information is needed.
Brick wall is inside apartment... what is on other side of wall?
Open existing electrical box. Drill through back of box and drill through wall until you come out on other side of wall. Install new box #1 on wall where drill comes out. Run conduit over to another new box#2. Drill through wall again until you come out on inside brick wall where you want to relocate original box. Install new surface-mount box#3 on brick wall. Then run wiring from original box. Original box cannot be bricked over or covered with building materials since it is a junction box where wires connect.
Other option is to install extension ring on top of existing electric box. Run conduit across face of brick wall. Install new box#1 where you need outlet.
Other option is to chisel away the brick and mortar from existing electric box down to floor level (or over to door frame). This will allow recessed conduit that can be concealed with matching mortar. Then run conduit across to new location. Cover conduit along floor with baseboard, or chisel out brick along floorline to accommodate conduit, then mortar over conduit. Or simply paint conduit to match brick. You must use conduit since wires cannot be run openly.
Gene
Aug 04, 2013 | Electrical Supplies
How do i install a new ringtone for incoming messages on a samsung s5600 mobile.
Hi, you have to download new ringtones for you phone by browsing with the phone, downloading and installing the ringtone and you follow the steps below to use your desired ringtone..
  • Go to menu display and light and press for widget.
  • Tick sound settings box and click out to main screen.
  • Pull across the little tap at the side of the screen and press the phone icon.
  • At the top right hand side click the little box and scroll down to New message.
  • You will see a box containing Message alert type and another box with Message alert tone.
  • Just select a tone or go search for one by selecting sounds.
Hope this helps.
Apr 15, 2011 | Samsung S5600 Unlocked Cellphone with...
How to change message tone
You can try two different approach to change the message alert tone:
1) Go to menu display and light and press for widget
2) Tick sound settings box and click out to main screen.
3) pull across the little tap at the side of the screen and press the phone icon.
4)At the top right hand side click the little box and scroll down to New message
5) You will see a box containing Message alert type and another box with Message alert tone.
6) Just select a tone or go search for one by selecting sounds.
or
  1. Go to profiles
  2. Select new messages from the drop down list on the top right corner,
  3. Select message alert tone, choose sounds go to gallery and then
  4. select the tone that you want to set as message alert
Feb 25, 2011 | Samsung SGH-S5230 Cell Phone
April 2009 EURO VOX BOX CODES gone in Cork!! Need codes ASAP
ericavoconno go to menu,then type 1570.go to navisagation and press across to chorus and then move down and go to 01 instead of 00 and change to aa-26-9ef-2e9-14-d1-ae.this will work mate.this is from phil in cork
Apr 04, 2009 | StarTech.com StarView SV211K 2-port KVM...
Canon cd-4050
On the main screen tap the "QUIT" in the upper right hand corner of the scrreen. This should bring up a smaller box asking "Are sure you want to quit?" with a "Cancel" and an "OK" tab. Do not select either tab, instead tap you finger on the left side of the small box twice, then on the right side once, then again on the left side (L L R L) in rapid manner. This should bring up a small box stating you are in "Service Mode", tap "OK". This should bring up a box with 3 tabs at the top. Tap the "Battery" tab. The next box will have a tab on the lower left side "Exchange Battery", tap it, then tap "OK" on the next screen. This should set the battery install date to the current date and the expiration date 2 years out. Back out and shut down and reboot. You should no longer get the "Replace battery" message. The screen should display the new dates for the battery.
Hope this helps.
Dec 28, 2007 | Canon CD-4050 Path-Through Scanner
Amazon Fire TV Stick Logo
21 people viewed this question
Top Amazon Televison & Video Experts
john cordey
john cordey
Thomas Stauber
Thomas Stauber
Ron Harvey
Ron Harvey
Level 1 Expert
Are you an Amazon Televison and Video Expert? Answer questions, earn points and help others
