Question about Nokia 3230 Cellular Phone
Restarts after power on
My 3230 restarts after powering on and it keeps on doing this until i take out battery. I haven't installed anything new, nor have i recieved anything from bluethooth in recent days. Please help.. my phone is infected by comm warrior virus,my phone restart again and again after two two minutes.and it disturbs me. i request you to solve my problem .i m so tensied because of this.
Re: Restarts after power on
Posted on Nov 23, 2007
  • 45 Answers
please do the following ur datas cat be saved you can recover the handset.
1.insert the battery *,3,callbutton,and power on at the same time for few seconds
3.while the display shows "Formatting" text release the fingers .
4. after completing this please format your MMC and then use it.
this will surely work out
Posted on Nov 22, 2007
0 characters
3 Points
My samsung gt-s5300 keeps switching over into a vibrate mode and then the whole phone freezes until i take the battery out and restarts it.It only works for a short while and does the same thing.Is it
Use this method to hard reset your Samsung Galaxy Pocket S5300 phone: Enter *2767*3855# , or use volume up + power + home and wipe data
good luck
Mr Difallah walid
Nov 13, 2014 | Samsung GT-S5300 Galaxy Pocket
How can i reboot my iphone?
Hold down the power and home button simultaneously until the device restarts and the Apple logo appears.
Hope that helps!
Mar 05, 2013 | Apple iPhone 5
Phone start-up failed. contact the retailer
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Dec 05, 2012 | Nokia 3230 Cellular Phone
How can i format my nokia 7610 phone memory?
* Just type in *#7370# and wait till the phone restarts, remember that all data such as contact, photo etc. will be erase after this process.
* Another way is the Hard reset
(while the phone is turn off)
Long press ( * ) ( 3 ) ( call key ) then power the phone on,keep on holding the three keys and wait until the phone restarts.
Good luck...
Jun 24, 2011 | Cell Phones
My nokia N79 is getting restarted frequently. kindly help & do the need full. Rgds Vara Prasanna
Mostly phone that keeps on restarting is due to lack of memory requirement that the phone needs. If your phone memory does too many data stored such as messages,video,games & application etc. it will not run smoothly and keeps restarting because it needs a space to generate any operation on your phone.
To get out of this madness, delete some files and stuffs of your so the available phone memory space will be free.If still the problem occur then you need to reset your phone. But before doing this be sure all files of yours are backed up because everything will be erase and then it will be back on original settings.
By doing reset, just type in *#7370# then wait until the phone restarts.
or you can do hard reset by long pressing ( * ) ( 3 ) ( call key ) then power the phone on (continue pressing the 3 keys and wait until the phone restarts.
Good luck....
Jun 24, 2011 | Nokia N79 Cellular Phone
I installed a theme in my Nokia E63 after installing the theme, the screen went blank white, and I can only see the battery meter and signal meter. The rest is blank white. I restarted it, it restarts but...
hmmmm... problem... Well if you want to format your set. then do the following
turn off your mobile
press and hold these buttons
* 3 and green button and power button
hope this will work
Mar 16, 2011 | Nokia E63 Cell Phone
NOKIA 3230 - 'Switch on' problem Hi, My nokia 3230 mobile got switched off on its own and I am unable to switch it on since few days. Even the logo "Nokia" is not appearing on switching the power switch....
Hi ,Try to charge your mobile with another same model battery, switch it on.. and keep it swiching on for five mins,, and try with your battery .. its really works.. this is all because your battery charge limit is gone under minimum
May 30, 2009 | Nokia 3230 Cellular Phone
Try the following manual method to hard reset/format Nokia N95:
1) Turn off the mobile device.
2) Turn on the phone and quickly Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button. keep holding the keys untill the mobile phone restarts and prompts you to enter details time and country.
Warning: Make sure the battery is at least 25% capacity so the phone will not power down during hard reset. ( Hard reset normally takes about 2 minutes only).
Warning: Hard reset will format everythings in your phone ( Your contact, calender, photos, installed Apps, Etc.) and the phone will be returned to its original state as if it was purchaced new.
( Mini memory card MMC) will not be effected :)
Dec 06, 2008 | Nokia N95 Cellular Phone
Searching SVC and no CDMA
hi! may be the mobile fell on to the water! this is also be a one of the reason! The better idea is you instal new software to your mobile! then the problem does not came!
Thanking you...........
May 24, 2008 | Samsung SCH-u740 Cellular Phone
Nokia 3230 Cellular Phone Logo
60 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
