Question about Health & Beauty
Need a throttle cable for a Tisong Model number LT50QT-22 scooter....Florida dealer where can I find a Florida dealer to buy this cable
4 Suggested Answers
  • 19 Answers
SOURCE: drive hub ,swing arm bearings, oil seals worn out need serial #'s
Posted on Apr 13, 2010
  • 280 Answers
SOURCE: need to buy a throttle pod mine is no good on my
You can buy one of these throttle potentiometers at
Note the description and compatibility regarding the SN of your scooter so you are sure to get the correct part.
The pot is easy to replace if you keep several things in mind. Remove the throttle lever first by removing the screws holding it in place. When you reinstall the lever make sure it is even left to right, front to back, by loosening and tightening the screws. Remove the covers and note the routing of the wiring so that when you reassemble the console you do not pinch any of the wiring.
The part is about $50 and will take less than 1 hour to install.
The hardest part of the job is finding the small screws in the plastic recesses to remove the covers. When installing the screws remember to go easy when you tighten the screws into plastic. Hope this helps,
Posted on Dec 01, 2010
Terry Corrow
  • 10875 Answers
SOURCE: where can I find repair information on TaoTao CY50-A scooters?
Posted on Jul 16, 2015
I need a charging cord for my scooter. How do I get the model number off the scooter?
Hi do U need it for the charger or is it a scooter with onboard charger most use (IEC C13) CABLES if it's this type U can buy them of E/BAY OR MONSTER SCOOTER PARTS
Oct 09, 2016 | Health & Beauty
How do i speed up my jazzy select gt
Only by buying a faster model. They are powered by electric motors that are rated for a certain top speed. Any 'race tuning' is likely to reduce the life of the motor.
Also that is a low speed scooter. You would need one with decent steerable handlebars. Yours would probably unstable and difficult to control at speed.
Jul 28, 2016 | Pride Jazzy Select Gt With 2 Batteries In...
Please robin - try to understand - you tell me that the beeper is attached to the cable - i don't know where the cable is - don't tell me its by the controller - i don't know what the controller is or
the beeps are diagnostic beep codes and the sounder should not be disconnected,
count the number of beeps then refer to my chart.will tell you what problem is
2 battery voltage too low =fully charge min 8 hours
3 volts too high =contact dealer
5 scooter in freewheel or Brake trip=chech in drive then turn on
6 throttle wig wag faulty or not in center when turning key
7 throttle or speed pot wireing or faulty
8 motor faulty or wireing poor /disconnected
9 battery pack pads and terminals coroded .replace them £2 eachn from pride or controller faulty ..replace
Advisory the analog battery guages on these regulary go faulty and read over full get electrical friend to check battery volts 12.8 to 13volt =fully charged
Dec 29, 2014 | Pride Go-Go Sport 4-Wheel
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I need a key for a Merits Electric Scooter. On the seat post I found Merits *1030837*. Is this the model or serial number. How can I find the correct info and how do I get a key. Thank you, Dianne
Yes, the number on the seat post is a serial number for the scooter. Please call Merits in Florida at 1-800-963-7487 and ask them to send you a key. They may send you one for free or a nominal charge. If you need a key right away they will direct you to a local dealer who has one in stock. Hope this helps.
Dec 29, 2010 | NRS Merits S2351-ARMU Pioneer 1 Mini...
I have been told that i need to replace the leveler that you press to go forward and back ,i dont know what its called or where to buy it.can you help
Hi. The lever is called the throttle or wig wag.
You need to find out what make and model of scooter you have. Dont just go by the name on the outside of the machine. Look inside the panels or on the chassis for a brand name , model and/or serial number. Good luck. Neil.
Feb 22, 2010 | Health & Beauty
I have a 2006 tank 150cc scooter, boogs down, and now wont start
Sounds like you have etiher a fuel issue or a vaccum leak. return it to the dealer
Sep 01, 2009 | 2005 Honda CG 150 Titan ESD
Health & Beauty Logo
54 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
