How do I open the HT630 epos scanner TO REPLACE THE BACKUP BATTERY. IT still SEEMS TO BE HELD TOGETHER AFTER I take out the 4 little screws that are visible...
SOURCE: opening F-417 monitor
There are plastic tabs running along each side of the monitor. 4 on the top and sides, 2 on the bottom. Removing the case is more than a little unnerving, very snappy! I did it with a flathead screwdriver and quite a lot of force.
I have some pictures that may help, I'll post them if you still require help.
I think the idea is to press down on the tabs to disengage them from the front of the monitor.
Posted on May 17, 2008
SOURCE: Removal of Keyboard on a Toshiba L300.
I am just in the process of the same repair, and am at this step.
Look at the picture on step 7 of this guide:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
See where the red arrow is pointing? i used 2 slot screwdrivers, one on either side of this thing, and pushed up, towards the screen gently and then popped the keyboard up and over this catch.
Then, with the part of the keyboard nearest the screen held up on a bit of an angle, use a slot screwdriver to push from the bottom of the keybaord, near the ctrl and alt keys and it will pop right out.
Posted on May 13, 2009
SOURCE: Need to replace drive belt.
the fan impeller is held on the shaft by a set screw. the movement you are experiencing is the shaft disengaging from the drive area. mtnmark3400@att.net
Posted on Aug 07, 2009
upajos
  • 24 Answers
SOURCE: For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
Posted on Sep 01, 2009
How do you open box to replace new batteries on pride gogo scooter
The box is held together with a number of screws. Turn the battery box upside down and you should be able to see the location of these screws. Simply unscrew them and the box will open.
Jan 28, 2013 | Pride Health & Beauty
Trying to replace the little round lithium backup battery but it is held with clips. How do I remove the battery
Press the clip with a sharp point on the inside edge towards the outside edge and the battery will pop up. You may need to lever the battery up at the same time.
Feb 11, 2012 | Toshiba Satellite A105 Notebook
We have a MGE 30KVA. It experienced a crash of some sort. The technicians say the EPO button was pushed, but it wasn't I was the only one in the server room at the time, Anybody have something similar...
Ask the IT guys to print the UPS alarm history for you.... if the EPO was pressed then it will be recorded in the history.
Once you have the history it may be possible to work out what has happened
Thanks for using FixYa
Jan 04, 2011 | Computers & Internet
I TURN MY SCANNER ON AND WHAT POPS UP IS HT630 BIOS V2.03 MEM 4608KB > I JUST WANT IT TO BE ABLE TO SCAN BARCODES WHAT DO I DO?
receiving670: You must load a program to execute it. You can make your program using JobGenerator, or i can help you to develope it. Roberto Martinez padrino99@prodigy.net.mx
Oct 26, 2010 | Unitech HT630 BATCH Barcode Scanner
Just restarted a 9339-40 ups after moving it to another bldg. And it has no output now. Screen says epo needs reset. Any help?
Most follow the reset procedures to reset from a EPO shutdown. Usually it is a fuse on Powerware that needs to be pushed back in.
May 19, 2010 | Powerware 9330 40 (A40401110031112) UPS...
How to use scanner model is HT630
This handheld can be programmed to capture data, perform verifications, inventory, store entrances and exits, and many other applications. You use a software called Jobgenplus and is in www.ute.com page. If you prefer, I can get an application, just tell me what you require, so it can give you a quote.
Oct 07, 2009 | Unitech HT630 BATCH Barcode Scanner
A part felled down look like a little radiator under the battery have 2 hoses that have fuild in them the part was held up with four plastic screws that look like T screws
THIS PART IS EITHER AN OIL COOLER OR POWER STEERING FLUID COOLER. IF THE COOLER IS LEAKING, IT CAN BE BYPASSED BY PUTTING THE TWO HOSES TOGETHER WITH A FITTING AND TWO HOSE CLAMPS. GOOD LUCK, THANKS FOR AN HONEST RATING AND FOR USING FIX-YA
May 16, 2009 | 2004 Mitsubishi Outlander
We are using Unitech PT630, HT630 for our stock audit at various retail outlets. we get wrong barcodes while scanning. Most of the times, scanner return only 4-6 charectors or part of the barcode is read...
Algunas simbologias de codigos de barras pueden dar lecturas parciales (como el interleaved 2 de 5). Entonces verifica lo siguiente: el lector laser este limpio, y en la aplicacion puedes restringir la lectura a un numero fijo (8 por ejemplo) para que solo lea codigos de barras de longitud fija. Some bar code symbologies can be read in part (such as Interleaved 2 of 5). Then check the following: the laser reader is clean, and the application can restrict the reading to a fixed number (8 for example) only to read barcodes of fixed length.
May 12, 2009 | Unitech 630D PDT 2.5MBRAM LR CCD SCA
How to open ds lite
There are two cross head screws under the rubber feet at the slot1 side, there are two tri-wing screws on the left (stylus side) and inside the battery cover (under the battery) there is a cross head screw at the top and a tri-wing screw at the bottom (in the corner).
The screen is held together by 4 screws under the ruber pads and then the outer case slides up about 5mm and then pulls clear.
Take great care when putting it all back together to line up the volume and power switches and plastics as the power switch breaks quite easily.
HTH
Mar 02, 2008 | Nintendo DS Lite Console
47 people viewed this question
k24674
jasbo
jasbo
