Question about Casio Music
Casio ct360 keyboard right side not working - Casio Music
My Casio Ctk-3200 keyboard can't get switched on with the power line, but it works with batteries.
You probably have shorted out the power supply. Test it with an ohm meter for proper operation. If it's not working, replace it. If it is working, then the power supply board in the instrument is shorted and you'll need to take it in for repair.
Mar 09, 2016 | Casio Ctk-3200 61-key Portable Keyboard...
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Nov 30, 2009 | Casio Music
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 | Casio Music
Headphones arent working with keyboard
yes its in the keyboard jack.
Aug 14, 2009 | Music
Casio keyboard doesn't work with ac adapter
Check the adapter is the right voltage AND polarity for the Casio... I believe they usually take a 9 volt DC adapter with the center pin being MINUS polarity.
Jul 14, 2009 | Music
Where can i get an instruction manual for my casio electric keyboard ctk-720?
click here
Its available right off the casio website
enjoy
Sincerely,
Michael Scott
Apr 19, 2009 | Casio CTK810 61 Key Keyboard
Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Aug 25, 2008 | Casio LK30 Note Lighted Keyboard
Casio LK 200 and smf software
If you have the smart card slot you can save your songs to the memory card by using Anvil Studio which is a free program. Save your midi song in Format 0 and be sure to use channel 4 for right hand playing and channel 3 for left hand. Be sure to keep the file size under 80k if you have other channels active for other instruments!
Nov 06, 2007 | Casio Lighted Keyboard LK90STADMC
Music Logo
16 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Piyal Perera
Piyal Perera
Are you a Casio Music Expert? Answer questions, earn points and help others
