Question about Microwave Ovens
NN2909/NN-2959. My cooktop bulbs blue out together! Changing bulbs does not correct problem. Is there a fuse somewhere? Any way I can fix this problem?
    Uploaded 5 video answers.
  • 47 Answers
Microwave oven model number but of course their is a fuse in anything. follow power cord from wall into cooker and look for a fusible link is what I would do. Both cooktops out at once is an indication of no power.
Posted on Dec 29, 2016
Cooktop light not working
actually, you need to remove the bulb and replace it with equivalent if still not lighting confirm if the light point is powered from pcb.
Nov 25, 2012 | Panasonic NN-P294SF Microwave Oven
No power on microwave panasonic NN-S255
It all depends on your full model number (you left off the suffix) but one version's service manual is here.
In some cases, it is a fuse or thermostat / thermal cutout / TCO, in others a surge has occurred, requiring circuit board repair.
This surge can be from the power line, or due to blown cooktop bulbs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Panasonic parts at
Encompass here.
Dec 04, 2011 | Panasonic Microwave Ovens
The Mocrowave Panasonic NN P295 stopped working. Not a single light is on. I checked the power at the receptacle - is OK. May be the fuse inside the microwave was blown. How can I replace the fuse. Where...
Did you recently have trouble with the cooktop lights?
Sometimes when the cooktop lights blow or are inserted or removed while the oven is still plugged in, the filaments can short, causing a surge that damages the controller.
They can be repaired. More details here.
Nov 05, 2011 | Panasonic NN-P295SF Microwave Oven
Where can I get a manual for a panasonic microwave convection oven serial number 863170033 model number NN-2909 manufactured in June 1993. has the owner's manual for sale: ; scroll through the parts list in the All Parts section or limit your search to the Microwave documents in the box on the left. is the direct link.
Unfortunately, I do not see the NN-2909 listed at any other site.
I hope this helps.
May 28, 2011 | Smeg FMC24 850 Watts Convection /...
Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Sep 11, 2009 | Microwave Ovens
Panasonic microwave model NN-2959: can't open door.
Hi! if the parts is to much expensive i think it is not worth it. considering the years it has serve you.
Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
Jan 23, 2009 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-H664 1200 Watts Microwave
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job.
It's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
To order Panasonic parts see ; To download a Panasonic manual see ; to find an authorized Panasonic servicer, see ; For FAQs, see
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Panasonic NN-H664 Microwave Oven
Panasonic NN-S789WC - No power on Display, Fuse OK, bulb Lights
The fuse will be a white or gray ceramic fuse, and you really can't tell if it's blown without actually measuring it. If a new fuse blows when you hit START, you probably have a shorted high voltage capacitor. If you have replaced the fuse and still have no display, then it sounds like there's a problem on the control board. The control board has a built-in surge protector which can short (and smoke) and when it does, it will cut the power to the control board, but not blow the fuse. We repair these nationwide for only $39.95 postpaid. If you or a friend want to check it out or send the control unit in for serivce, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa:
Mar 02, 2007 | Panasonic NN-S789 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
