Question about Casio Music
Casio ct360 keyboard left side not working - Casio Music
How to replace a defective speaker on the Casio CT-638 tone bank keyboard
Hi, Yes it can be fixed.
It may not need fixing, It may have just worked loose. If it is faulty then any general purpose speaker that will fit will be OK. Consider replacing both if the replacement is radically different.
Speakers can be as cheap as a few pounds.
Paying someone to do the repair is something else. It will take longer to take the keyboard apart than affect the repair.
Consider buying a replacement from eBay, second hand, and get a competent amateur to repair yours!!
Failing that, use the headphone out (which cuts the internal speakers) into a hi fi or external instrument amp.
Good luck, Chris the Fader.
May 21, 2014 | Casio Ctk-5000 Electronic Keyboard Piano...
Problem with casio CTK-691 keyboard
"can I do it my self or should I go to a professional to get it repaired"?
Get it repaired by a professional. Casio gives long warranty (5 years in Australia). Mine took weeks for Casio Service to repair. Many boards had to be changed.
Jan 25, 2012 | Casio Ctk691 Keyboard
How to turn the volume on my casio keyboard
It is difficult to answer your question without knowing the model no. of your instrument.
Most keyboards have a slider closer to the left side, a round knob for controlling the volume or a juggle switch in the middle which might be used for controlling many options including volume.
Switch on the keyboard and look for the word 'volume' near the controls. If you can't find it, experiment with the controls. Try one controller at a time and it won't damage your instrument.
Oct 30, 2011 | Casio Music
I want to find the year this keyboard was made
It is hard to help wihtout knowing the make and model of the keyboard but here is a starting point for your search. There is a menu on the left of this site with additional information.
Chronological order of their main products.
http://world.casio.com/corporate/history/chronology.html
Oct 18, 2010 | Casio Music
Headphones arent working with keyboard
yes its in the keyboard jack.
Aug 14, 2009 | Music
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
From left hand side 10 keys not working
You might check settings first. The keyboard might be set to a mode where those keys have some function besides notes. Try a master reset and see if hings start working.
If it was working and now those keys don't, a fault has probably developed. There may be problems with connections to the keyboard, or there's been a component failure.
Sometimes getting into these things and accessing the keyboard is a challenge, and it's possible to do more harm than good. If it needs repair, you're probably better off taking the keyboard to a musician's store in your area and asking them to give you an estimate for the work (or to recommend a servicer if they don't do the work themselves).
Nov 26, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Midi
Anvil Studio is an easy way to prep midi files for keyboard use, save channels 3 & 4 "left & right" in Midi 0 format and it will light the keys properly. Keep your file size under 80k!
Oct 26, 2008 | Casio Lighted Keyboard LK90STADMC
Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Aug 25, 2008 | Casio LK30 Note Lighted Keyboard
Casio LK 200 and smf software
If you have the smart card slot you can save your songs to the memory card by using Anvil Studio which is a free program. Save your midi song in Format 0 and be sure to use channel 4 for right hand playing and channel 3 for left hand. Be sure to keep the file size under 80k if you have other channels active for other instruments!
Nov 06, 2007 | Casio Lighted Keyboard LK90STADMC
Music Logo
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Piyal Perera
Piyal Perera
Are you a Casio Music Expert? Answer questions, earn points and help others
