Question about John Deere Garden
Where's the fuse box on John deere 6300 - John Deere Garden
  • 8 Answers
SOURCE: ust changed the fuel pump on John Deere 6300 and will not start
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
Posted on Feb 21, 2009
wireguy212
  • 1627 Answers
SOURCE: need the pto to work on a 6300 john deere tractor
If you have tried a new sensor and a new switch the the next step is to replace the pto solenoid valve.If that proves fruitless then the b.c.u.needs to be replaced or bypassed.The solenoid valve will cure your problem 90% of the time.If that does not work,let me know,i can tell you how to by-pass the b.c.u..
Posted on May 08, 2010
hunter19_46m
  • 7482 Answers
SOURCE: john deere tractor 6300 tractor starts then shuts off after 5 seconds on first start
Hi thelayfamily
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Mar 31, 2013
  • 50269 Answers
SOURCE: How to access gear box on john deere 2040s tractor.
unless you have lots of mechanical skill you can not do it it requires splitting the tractor in half with stands and rollers .
Posted on Aug 02, 2016
Testimonial: "I have completed the job, access through a panel in the cab floor pipe just pushes on."
emissionwiz
  • 78267 Answers
SOURCE: I need a belt diagram for a John Deere 6300
Does this look right?
Posted on Sep 07, 2016
Need a fuse box diagram for a 2006 John Deere 5203
http://pdfstream.manualsonline.com/1/13e55f8e-9640-eb94-e527-19f180da91ca.pdf
Fuse info is on starts on page 14-22 of pdf file at the above link (in blue). It is a large file give it a minute to download.
Jan 20, 2017 | John Deere Garden
Where is the fuse box on a 2005 John Deere trail buck 500 please send me a text ************
Go to upstateoutdoorpowerequipment.com. there you can get illustrated parts diagrams for your mower. You may have to look up the motor type which should be on a plate on the motor itself or you may have to look up your mower brand and year. Though I don't think it'll have a fuse box. There usually is a fuse under the hood close to the firewall somewhere.
Oct 22, 2016 | John Deere Garden
Hello, I have a john deere 6300, ever since I have had it, it says on the dash board 'dia'? Could I please explain how I could fix it so that it shows the hours and power e.c.t. Thank
I'm sure if you call your local John Deere dealer, they would give you an answer. You can find your local Dealer(s) here... http://dealerlocator.deere.com/servlet/
Jul 08, 2014 | Garden
John deere 6400 no power
CHECK MAIN FUSE IF THE FUSE BOX IT IS THE FIRST ONE AT THE TOP IF YOU LOOK IN THE I THINK IS M1 FUSE 30 AMP
Oct 09, 2012 | John Deere 6300,6300l,6400,6400l Tractor...
Need the pto to work on a 6300 john deere tractor we have changed the fuses and changed the sencer on the back can you help
May 03, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
4 wheel drive not working on a 6300 model
The 4 wd need to have power to get out of 4wd.If you can'get into 4wd then you need to check the 4wd box it's self for worn or missing gear,if you can't get it out of 4wd then check for power to the 4wd solenoid.There should be power power present in the off position.
Aug 05, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Garden Logo
143 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
