Ct360 keyboard left side doesn't work - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 26,232 Answers
Replacing the faulty keyboard should fix that.
Posted on Dec 29, 2016
How to fix acer aspire 5920 left side key board ?
Sounds like the keyboard is faulty. Replace the keyboard.
Jul 29, 2015 | Computers & Internet
When using the keyboard, every time i click the letter b on it, it causes Window's Media Player to open. But the Ctrl key on the left side doesn't allow me to use short cuts in my programs anymore...
Sounds like your cntrl key might be getting stuck..
A couple of things you can do. you can take the key off, and clean round the key. And Believe it or not, you CAN put the keyboard in your dishwasher, but you have to shake out the left over water and let it sit for about 4 days.
Also try a good dust cleaner to see if that will help.
Jul 16, 2011 | Logitech Computers & Internet
My Yamaha mm6 doesn't work stereo, just mono. when u put 2 cables it works from right channel, but if u put to the left channel, works from the left. I don't get it.
There is probably a setting that is wrong. The left channel is the default for mono operation. Look in your user manual regarding "PAN" which controls the output going side to side. You MAY be "panned" clear to the right. When you plug into the left, it is the default so in spite of being panned right, they would send signal to the left IF nothing is plugged into right.
Jun 14, 2011 | Yamaha MM6 61Key Synthesizer Keyboard
The shift doesn't work. with caps-lock i can make the capitals, but not with the shift. either left or right. an external keyboard on the laptop did work.
Kindly run Dell Diagnostics.
Boot to F12.
Select Dell Diagnostics.
Custom test for Keyboard.
If shift key failed you need to have your keyboard replaced.
May 18, 2011 | Dell Inspiron 1525 Notebook
Hi . Please could you explain for me , I have formatted my netbook, and then the keyboard that I use on the netbook not works correctly. Left side of the keyboard works properly, right side doesn`t works...
The numlock must be ON - just press function key and Numlock key (Both must be in same colour - maybe Blue) and the keys should work - If the problem is solved then enter the BIOS setup and reset the Power on Numlock to OFF so that it will be off any time you start the windows.
Nov 16, 2010 | Computers & Internet
My Right side SHIFT-KEY on a keyboard of HP-Compaq nx5000 Notebook is not working. Is there any solution?
maybe the under-button rubber is corupted try to clean it
also u can use the left one for a while.
Jun 05, 2009 | HP Compaq nx5000 Notebook
Cleaned coke off keyboard, not disconnected, wiped over all keys on left side of keyboard. Now nothing works on keyboard at all. How to reset?
Try disconnecting it once and connecting again after restarting...the same thing happened once and disconnecting worked..otherwise just restart and checck the cable is connected properly..
May 27, 2009 | EzKey EZ-8000 Smart Office Keyboard
Inspiron 5100 bios a32, keyboard
You can try reseating the keyboard connector. If that doesn’t work, the keyboard needs to be replaced. To reseat the keyboard connector, follow this link: http://support.dell.com/support/edocs/systems/ins5100/en/sm/keyboard.htm#1084976
Be sure to remove AC power and the Battery.
Nov 01, 2008 | Dell Inspiron 5100 Notebook
SCREEN TURNED TO LEFT WHEN I HIT KEYBOARD WITH BOOK COVER
1. If you right click on the desktop and look at graphics properties, or something similar to that, then you should get a menu for your display adapter control panel. Usually the screen rotation is right there. Sometimes it's as easy as a CTRL + arrow key combination, but I'd rather see you adjust it from a menu.
2. Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees (If that doesn’t work, try Ctrl-Shift-R)
3. If you have the intel video chipset, I believe pressing CTRL+ALT+ one of the arrow keys should fix your problem.
I think it was ctrl+alt+right, but if that doesn't work, try the other three arrow keys.
However, if that doesn't work (especially if you do not have intel video), then right click on your desktop, go to properties, and go to the advanced tab. There you should find some setting that will allow you to reverse the rotation.
Dec 06, 2007 | Logitech Cordless Desktop EX110
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
