Question about Kenmore Dishwashers
Rinse aid dispenser says empty, but is actually full. Machine thinks it is empty, so wash times have increased. How do I fix this? I have a kenmore elite dishwasher, Canadian model #630.12903312,
Canadian kenmore elite model 630.12903312 2 years old Empty rinse aid indicator light is always on, even though it is full
3 Suggested Answers
codfish124
  • 36 Answers
SOURCE: Dishwashing detergent in rinse aid compartment
not good there is no way to drain it out. you might be able to take the door apart and take off the rinse aid reservoir and clean it out
Posted on Dec 20, 2008
SOURCE: put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Posted on Apr 30, 2009
I put rinse aid in but it seems to not be working or at least it keeps showing that it is full and it doesnt go down? Also it seems that there is always detergent left in the slots after it gets done...
The rinse agent dispenser holds up to 8 ounces of rinse agent and only 2-3 small teardrop sized drops are added in the rinse cycle ,thats all it takes per cycle so a full dispenser could take 2-6 months to become empty depending on how often ya run the dishwasher.
As far as some detergent remaining,check the filter in the bottom of the tub for some blockage,if the water cant spray forcefully because its hard getting into the pump from filter blockage it cant wash that well
I hope this helps
Gene
Aug 03, 2011 | Kenmore Dishwashers
Accidently put dawn dish detergent in rinse aid dispenser. what do I do?
Get a turkey baster or something like that and pull it all out of there...then flush the rinse-aid holder out with wateer a few times pulling the water and soap mixture out each time so that you dilute the soap...
Then run a few cycles empty with no other soap so that you get everything out of the holder...
that will get you back in business...
heatman101
Mar 14, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Hi.I have rinse aid light on since yesterday and i cant figure out wath is it about
It means the dispenser for rinse aid is empty . Fill the rinse aid dispenser with rinse aid
Feb 24, 2011 | Washing Machines
My dishwasher is leaking huge amounts of foam to the floor. This is what happened before I ran the cycle: I had mistakenly poured detergent into the "Rinse Aid" slot in the inner side of the dishwasher...
OK.... The rinse aid dispenser holds enough rinse aid for a lot of washes and dispenses very little each time. So you may nedd to have the dispenser emptied by a technician. If you take the door liner off you can see the back of the dispenser and maybe you can work out how to empty it. Holding the actuator in manually could allow the rinse aid dispenser to run out. Then wipe the tank dry with a towel. Putting high fat milk in the machine while it is rinsing will neutralise the foam. Just one cup will do. Good Luck.....T.
Aug 01, 2010 | Dishwashers
My Kenmore Elite dishwasher gives a message "Rinse Aid Empty". What does this mean?
It means the rinse aid dispenser is empty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool gold diswasher - sudddenly dishes/glassware/silver are all cloudy. rinse aid doesn't help. have tried running machine empty to "clean out" pipes, etc. plz help.
alot of people think the rinse aid is full but, its not. how to properly fill unit.
1. open compartment
2.fill with jet dry
3.close compartment
4.lower and raise door 3 times
5. open compartment
6.add more jet dry
7. lower and raise the door to see if it still looks full.
the reason for this is there is air in the dispenser and this process will take out the air to be completely filled the dispenser.
Mar 05, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Put rinse liquid detergent in dishwasher rinse aid compartment.
Apr 04, 2009 | Kenmore Dishwashers
Rinse solution stays on the glasses
First chech the machine is warming the rinse water and not rinsing in cold water then have your chemical guy come and check that the soap/rinse ad dispenser is not dispensing too much rinse aid and naturally make sure the machine is in fact ricing with water I have had it where a glass washer takes more rinse aid then i should and does not actually rinse with clean watr it was simply spraying the rinse aid wich sounded as if it was rinsing soulution was new pc board it was not changeing programs properly if you have and older machine it proberly has a timer this too can be a cuase of the problm if it is not clicking over to allow a full rinse cycle.Hope this helps let us know.
Jan 17, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Rinse aid not being released
Most likely the actuator for the rinse aid dispenser is not functioning.
Jan 13, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Kenmore dishwasher model 665
rinse aid generally dispenses automatically in cycle, very small amount every time. why do you think its not dispensing?
Feb 22, 2008 | Dishwashers
Dishwashers Logo
56 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
