Question about Facebook Computers & Internet
Did police open fire on Standing Rock water protector and protectors.???
Was on Facebook this morning . I believe it was a friend posted from current news or current affairs ???
  • Facebook Master
  • 2,189 Answers
It appears that it may be true
Posted on Jan 04, 2017
Can I plug a space heater into a surger protector
You can as long as the surge protector is rated for the same current (say 15 amps) as the space heater. If you must plug into a surge protector, be sure that is the only device that is plugged into the surge protector. It is not advised to plug in space heaters into anything except a wall outlet...not even an extension cord as the current draw from space heaters is usually the maximum current flow for any single outlet. Honestly, I would advise against it.
Nov 14, 2017 | Heating & Cooling
No water is filling in my machine
Good Afternoon Friend,
I understand that your Frigidaire dishwasher, model# FFBD2411NS, will not fill with water. First make sure that the water supply, to your dishwasher, is turned on. Next, make sure the overfill protector moves freely up and down. You will find this located in the front left corner of your appliance. This keeps your appliance from overfilling. Make sure you clean this occasionally with household cleaner containing vinegar or bleach to dissolve any buildup. The overfill protector should move up and down freely about one inch. If it does not move, lift and clean underneath. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire FFBD2411NS
Water is not coming into my frigid wire dishwasher?
Good Morning Friend,
I understand that water is not coming into your Frigidaire dishwasher, model# PLD2855RFC. There are a couple of things that I would check.
First, check to make sure the water supply is fully turned on.
Secondly, check to make sure the overfill protector moves up and down. The overfill protector keeps your dishwasher from overfilling and is located in the left front corner of the tub. The overfill protector should move up and down freely about one inch. If it does not move, lift and clean underneath. Clean this occasionally with household cleaner containing vinegar or bleach to dissolve any buildup.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 25, 2014 | Frigidaire PLD2855RFC Dishwasher
Unblock the facebook site that is being blocked by k9web protector
One thing you can do is to turn off the K9 web protector by uninstalling it or changing its settings which both requires a password.
Another thing Is to use proxy but this won't work if proxy sites are also blocked by K9.
On Windows, your could also disable the K9 web protector if you have an administrative privileges on your PC:
  1. First go to Start.
  2. Click Control panel.
  3. Click on System and Security .
  4. Under System choose Device Manager.
  5. On Device Manger window, Click View then Check Show Hidden Devices
  6. Look for Non-Plug and Play Devices and Expand it by clicking on it.
  7. Under it, Look for bckd then Double click on it to open its properties.
  8. Then on Startup type choose Disabled.
  9. Click OK then restart your computer.
  10. After restarting, Repeat steps 1 to 7, The current status should be Stopped
  11. If not, Click on Stop button and Click OK and restart once again.
Jul 23, 2011 | Computers & Internet
I had to unplug my tv today (actually the TV is plugged into a surge protector, so I unplugged the surge protector.) when I plugged the surge protector back in the TV wouldn't go on (acts as if its...
There should be a surge release button on the surge protector to bring the protector back to normal (should be red in color) Some surge protection devices have this option so just check if your s has it. If that is not the case than I think that you might have blown a fuse in your TV.Might just have to open it up and change the fuse within with the same ratings, but please be careful because do have high voltages so get an experienced technician to do this for you.
Good Luck.
G.
Jun 29, 2011 | Televison & Video
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
Nov 08, 2017 | 3Com Computers & Internet
Taco timers and Surge Protectors
Do they run at the same time? The two items consume
a lot of power. Check the voltage when they are turned on. If the voltage is below 90 Volts. The power surge at your Taco is great. Then, the surge protector could not
handle the current inrush that's why it's blown off. You
must install a surge protector that can handle the Taco
current inrush.
Sep 06, 2009 | Plumbing
Will not fill with water
The problem is most likely the water inlet valve. This is a solenoid that opens when there is power to it. It is a common problem on dishwashers and washing machines.
They are not very expensive and are usually fairly easy to replace.
If you need more help, post a comment.
Thanks,
Tim
May 27, 2009 | Frigidaire PLDB998A Built-in Dishwasher
Electrical unit attached to compressor keeps making a spark(clicking sound) Fridge & freezer slowly stopped cooling during the day and is now down to 0 cool.
Overload thermal protector is tripping out. When a mechanical refrigerator is unplugged it should remain unplugged for 5-10 minutes to allow the refrigerant pressure to equalize. If you unplug it and then plug it right back in the overload will open on and off until the pressure in the system balance to the point where the compressor will start.
This protector is a two way protector. It opens on Over current and or over temperature. If a condenser is plugged with dust , hair or what ever the fan which circulates the air for cooling the system will not move enough air to keep the compressor with-in operating temperature range. The thermal protector will open.
May 03, 2008 | Refrigerators
Computers & Internet Logo
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
