Question about Zanussi Washing Machines
Zanussi jet system control panel stopped lighting up though off on button still works, what can I do?
4 Suggested Answers
  • 1294 Answers
SOURCE: zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Posted on Jan 02, 2008
  • 86 Answers
SOURCE: Zanussi washer dryer jet system does not work
Hi, this problem is caused by the recirculation pump which has either gone faulty or has been clogged up by to much washing powder/liquid! you will need to strip the machine top off first then the rear and the pump is located at the rear of the machine (depending on model ) it is easy to spot as it is the only one that has the hose attached to the pump which leads to the door seal. take it off check for blockages in the pump and pipe and hose if no blockage then replace pump. It will then work like new.........!
Good luck...................
Posted on Jan 02, 2009
SOURCE: ZANUSSI ZWF1237W 2 YEARS OLD NOT WORKING
The motherboard is blown the part is covered under warranty which will take 4-5 days to come in and I have to pay for the labour.
Posted on Jan 23, 2009
My cruise control on my 2001 Kia Sportage stopped working.
Check your repair manual where the vacuum hoses for the cruise controls are (engine bay). Maybe one of the hoses came off or has a leak.
Feb 29, 2016 | 2001 Kia Sportage
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
ERROR CODE E 60 washing machine zanussi ZWG1100M
This can be due to error in the control board. Shut down and remove plug and when switched on press down the start/stop button. If the error does not clear this can be a fault in the motor drive within the control panel board.
Remove the panel and check the connections to the motor, check the motor and the capacitor to the motor or if the motor is jammed.
Jul 03, 2012 | Zanussi Washing Machines
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
May 27, 2011 | Zanussi FJS1225W Front Load Washer
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
E 20 ERROR ZANUSSI JET SYSTEM
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Sep 07, 2009 | Zanussi FJS1225W Front Load Washer
Jan 22, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi jet system 1200
Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi 21 in. DCE5655 Free-standing Dishwasher
There is water in the bottom panel which has activated the float switch which overrides everything to stop the room the dishwasher is in from flooding. Remove the panel look for the leak. In my case one of the pipes had come off. There will be a lot of water in the panel so try and drain it first, tip the washer forward over some sort of container to catch the water. In my case I got very wet.
Jan 01, 2007 | Zanussi 21 in. DCE5655 Free-standing...
Washing Machines Logo
29 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
