Question about Tools & Hardware - Others
I have the attach a file staple on my text screen and I can't get it off! HELP!!
How do I take a picture of my text on my phone and then send in an e-mail
Take screen shot of your screen (power and down arrow simultaneously).
Then attach that file as a pic to your email
Mar 30, 2016 | Google Nexus 5
Stanley TR 150 staples only going in half way. Why?
Hi Rene:
Don't know what materials you're working on, but you need to match the staple length with the thickness of the product being attached and the hardness of the material you're stapling into.
The intent is to attach one product to another. I'd go to a 1/4 inch staple for your application.
Jul 25, 2015 | Stanley ®Bostitch TR150 Staple Guns Tools
Why won't Easy Shot staples advance/shoot?
Hi Elaine, The EasyShot stapler is a bottom load stapler. Please follow the steps below to make sure you are loading the staples correctly.
- Turn the tool upside down so that you can read the text "use light duty narrow crown" on the bottom of the magazine
- Open the magazine of the tool
- Place the staples inside the channel (not on the back of the magazine rail)
- Close the magazine.
Attached is a picture so you can see where to place the staples.
If you are still having trouble please contact our customer service department and we can assist you further.
May 29, 2015 | Staples Tools & Hardware - Others
TROUBLESHOOTING; TWITTER,When I try to RT (Copy/paste) the text shows up, but no picture! HELP
I am not a user of Twitter and most social networking sites but have a high level of knowledge about internet functions. In most cases when it comes to copy/paste function images a lot of the time are not allowed to be pasted as part of text since they are not text. Sometimes when you copy text and image together the copy function strips everything down to text which in the case of an image is not possible. You might see sometimes once you paste that the file name is there but not the image itself and most other times you only get the text. The image in the text has a place holder but that place holder is not copied. As for twitter I would assume that you might have to attach the image file using their file attachment function after you paste the text.
Oct 04, 2014 | Computers & Internet
My bar stool has a very hard seat. How can I make it softer?
There are a few possible solutions to your problem thatdepend on the type of chair you have. Ifyou have a wooden or metal barstool with no fabric over the seat, I recommendeither placing a removable cushion there, or attaching one permanently withstrong glue. If your barstool is alreadycovered with fabric, the fabric is probably stretched and attached to the undersideof the seat with strong staples. Take astandard staple remover and pull out the staples. Then, insert any kind of soft fabric likecotton for example. Next, fold theexcess material back under the seat and attach it with staple gun staples. Make sure the staples are not reaching throughthe material because they could poke someone.
May 29, 2012 | Furniture
How do I forward a media text message?
Open your text window for whoever you're going to text. Press the menu button (4 horizontal lines) and press the "attach" option. This will let you attach a sound, picture, or video file stored on your phone. There is a size limit to the files you send.
May 04, 2011 | LG Ally Cell Phone
Hi i have a samsung galaxy s and i want to know how do i save pictures from text messaging memory card pls help thank u
Follow the following steps:
The context menu may differ on your screen depending on the version of your android.
1. Open the text where the picture attachment is
2. Tap and Hold the Picture and wait for the popup selection menu
3. Select Attached items
4. Tick the box before the name of the Attached file
5. Click Save.
5. Open My Files under Applications
6. Tap on Download Folder. Your should find the file here.
7. Tap and hold the file for more options.
Hope it helps.
May 01, 2011 | Samsung Galaxy BBSPHP1 Tablet PC
There's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
May 31, 2009 | Staples Swingline® 36115 Staple Guns Tools...
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
Unable to open e-mail attachment
Open Files with .MSG File Extension Do you want to open a message with the Outlook .MSG file extension? The Encryptomatic MSG File Viewer makes it easy access Outlook MAPI message files (.msg files) created in Outlook 2000/XP/2003.
MSG Viewer reads .msg files encoded in western characters. It will display the text contents of the .msg file on your monitor. You can also print the message, save it to a text file, and extract file attachments.
Easy to Use Encryptomatic's Outlook .MSG Viewer is simple to use. It may be optionally installed as the default .msg file handler. This enables you to display a .msg file by simply double clicking it.
Extracts File Attachments from Outlook .MSG Message Files
Users can extract and save to disk any file attachments that were included in the Outlook .msg file, a useful feature not found in other viewers of this price class. To extract email attachments, just double click on the file attachment and save it to a directory.
viewer-screen.jpg What it Doesn't Do
The MSG Viewer is designed to give you quick access to an .msg file's text contents, file attachments and header information. It does not render colors, formatting or graphics, and it is not a full featured substitute for Outlook. With an RTF message with colored text and font formatting, the text will appear in black and white and the paragraph formatting will be lost (as in the message above). MSG Viewer displays only Western characters.
Feb 26, 2008 | HP Pavilion dv6000z Notebook
Tools & Hardware - Others Logo
41 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
