Question about Samsung Televison & Video
With my fire TV stick connected to the HDMI port and USB power source. I cannot get my TV to recognise the existence of the fire stick. What do have to do?
My Samsung TV has 2 spare HDMI ports - tried both with no effect from either. I asume that the Select button on fire stick should make the connection? Would there be a time delay?
  • 208 Answers
SOURCE: HDTV connection on TV is not HDMI
The port is called a DVI input. You can find a HDMI to DVI adapter at Circuit City, Best Buy, Ultimate etc..........
Posted on Feb 10, 2008
  • 265 Answers
SOURCE: HDMI PORT STOPPED WORKING!!
the best option here is connect via a standard PS2 avi cable or componet cable until your tech guy comes out!
Posted on Apr 30, 2009
SOURCE: Help Playing .mkv File on Samsung UN55B6000VF
The solution is very easy, format your usb drive to NTFS and go on.... FAT file system have that problem, it not copy big files....
Posted on Aug 03, 2010
SOURCE: Printer connected to a Asus
I'm having the same issue with the same router and printer (mine is CLP-300/XXA).
At first when I try t print a pdf file or an image or any text/word document file with pictures/images I get an SPL-C error.
I have upgraded the firmware and it worked great on my laptop! Then, I tried to install the printer driver on my desktop, but now none of them work correctly.
Still not solved, but here are some suggestions:
1. Try to upgrade the firmware. 2. Try to install the original samsung printer driver 3.0.1
3. If it didn't work try to install the updated driver 3.0.4 4. If it didn't work try to install the Universal Printer Driver
5. IMPORTANT: between uninstalling and installing driver, disconnect both printer and router A/C power adapter and try to reboot you PC after removing the previous driver!
I'm going to work on it and see if it works. The DD-WRT firmware solved the exact same problem on my previous RT-N13U router, but unfortunately DD-WRT doesn't support RT-N56U yet!
Note: I called ASUS and they told me that Samsung printers are not supported for printer sharing server :(
Posted on Jun 27, 2011
  • 1746 Answers
SOURCE: when i plug an hdmi
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
Posted on Jul 22, 2011
Codes to upgrade hisense40h3e to a smart tv
There is no code to turn the Hisense 40H3E into a smart TV. This TV doesn't have the network LAN or WI-FI hardware or software. You can only add network streaming by connecting a streaming stick (Roku, Fire, etc.), streaming box (similar items) or use a computer. Most streaming devices connect to the HDMI port; you may need an HDMI switch to share the TV with multiple devices.
Note: the USB port on this TV may not supply sufficient power for some streaming devices. You may need to connect them to an USB power supply to a standard outlet.
I hope this helps.
(the 40H3E does support viewing files from a USB flash drive - see the manual for the list. I found the manual on Manuals Lib here: https://www.manualslib.com/manual/1053975/Hisense-40h3e.html . )
Feb 18, 2018 | Televison & Video
Can i use a firestick with my sony wega kdf-e42a10
Fire TV Stick connections....
1 Connect USB cable into fireTV stick, and plug in power adapter. ...
2 Amazon fireTV stick and power adapter. ...
Connect fireTV stick to HDMI port via HDMI extender.
3 Amazon fireTV stick connected via HDMI EXTENDER CABLE TO Monitor HDMI port. ...
4 Turn on TV and select HDMI port
Feb 04, 2018 | Sony Televison & Video
Just purchased alexa fire stick, have only 1 hdmi port on TV, what to do?
If your TV is an older model and only has a couple HDMI ports, but you have several media sources, such as Blu-ray players or video game consoles, an HDMI switcher is exactly what you need. Connect all the media sources to the HDMI switch box via anHDMI cable and then connect the HDMI switcher to the TV.
Jul 30, 2017 | Televison & Video
Does my fire tv stick need a cable box to function or can I just plug it from my tv to the electric outlets
The Fire Stick just needs a HDMI port to plug into. The ones on the tv (assuming it's a newerish tv with HDMI connections) will work fine.
Feb 03, 2017 | Televison & Video
Having issues setting up the PS4 can't find the hdmi slot same size as the hdmi wire that comes with the console. Hdmi wire and tv shown in pic
  • Connect the included HDMI cable to your TV and the PS4's HDMI Out port Connect your console to your cable or satellite box Unplug the existing HDMI cable connecting your cable or satellite box to the TV and plug it into the PS4's HDMI In port Plug the PS4 into a power source Power on the PS4 Plug the controller into the PS4 using the included Micro USB cable Press the PS button on the controller to pair it with your PS4
Jan 10, 2017 | The Video Game Consoles & Games
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Dec 23, 2016 | Televison & Video
Fire tv stick unsupport
well there's your first problem right there !! fire sticks plug into a USB port not a hdmi port if your tv doesn't have a USB port then its not for using with a firestick
Oct 20, 2016 | Televison & Video
I can not find an HDM1 port on my Sharp TV. Can I use the USB Port?
No, the HDMI plug will not fit into a USB port. (It's the wrong shape and the pins are different.) The micro-USB port can be connected to some USB ports for power, not data, with the appropriate cable (micro USB to type A). (Without the model of your Sharp TV, I do not know if the USB port has the right specifications. Some older TVs only have a "service port" which doesn't always provide enough power.)
There are HDMI to component video/audio converters that may work. They do not always work with copy protected (HDCP) content. See http://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html for one example. (Composite video is not recommended since that will downgrade the signal to 480i. Component video supports 1080p signals.)
If you have 1 HDMI port, then a multi-port HDMI switch may work. Note: automatic switches often do not switch on their own with some sources. If the source never actually turns off, like some set-top boxes, you'll need to switch the unit manually.
I hope this helps.
Mar 05, 2016 | Amazon Fire TV Stick
Can i install a amazon fire tv stick the u s b will not plug in
Amazon.com: Customer Reviews: Amazon Fire TV Stick
www.amazon.com/Amazon...Fire-TV-Stick/.../B00GD...
Amazon.com, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ).
Amazon.com: Customer Discussions: Fire stick and Samsung TV issues
www.amazon.com/forum/fire?cdForum...cdThread...
Amazon.com, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
Dec 25, 2015 | Sanyo DP42849 42 in. HDTV
PS3 Connection problem with this particular tv model.
connect PS3 to Tv with RCA cables (white,red,yellow) go to display settings change to HDMI, Tv should go black remove RCA cables and connect with HDMI.
Jan 10, 2018 | Samsung LE22B450 22 in. HD-Ready LCD TV
Televison & Video Logo
42 people viewed this question
Jerry Greenberg
Jerry Greenberg
