Get fireTVstick to work with my TV - Televison & Video
What does "enter the characters as they are give 9n the challenge" mean and how would I find that?
it sounds like a captca requirement...one of those boxes that has characters, or a picture of charcters you have to enter to prove you are human...
Nov 09, 2017 | The Computers & Internet
How do I re-register my Firetvstick? See explanation below
Go into settings and change the date so it is right. Set it to use internet time or how ever it asks that question. Then restart tablet and try to register again.
Apr 28, 2017 | Amazon Tablets & eReaders
Hi, I purchased a firetvstick but it does not respond after plugged into my smart tv. help
Check list:
1) Do you have your fire stick powered?
Connected via usb cable to a power adapter
plugged into a power strip that has the power on,
power switch is off....so on.
2) Do you have your TV input set to the correct HDMI input?
Depending on the model you may have 2 to 4 HDMI inputs.
This is the most common error.
Please make sure the input is set to the correct input
of where your fire stick is plugged in to.
3) If you have power and the input in your TV is set.
And you still have nothing.
Then your firestick might be defective.
4) If it is working, read the instructions carefully.
connect your fire stick to your wi fi and register your fire stick.
Then enjoy!!
Aug 30, 2016 | Amazon Fire TV Stick
I bought a firetvstick but can not get it to start
You have to register the TV over the Ethernet with Amazon.
See the page here which explains how to do it.
Register or Deregister Your Amazon Fire TV
Feb 12, 2015 | Computers & Internet
Remote sensor not working on TV. Tried the original and several other remotes and none are working. Used new batteries.
pls. check tv is in chaild Lock mode / LOCK mode.
so check tv panal key use . is working ? NO then tv is in chield lock mode. see user's menual and set chaild lock trun off.
chek with new remot cantrol if not work then problum is tv set
[1] see tv frant panel on IR [simbol] clear with cloth smuthly [dust free]
if not working Remot cantrol then problum is inside tv .pls check tv by nr. tech.
Oct 30, 2009 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
