Question about Exercise & Fitness
My fitbit is not showing the correct time all of a sudden
I let my fitbit battery die and now the clock is wrong and I do not know how to set it. can you show me how to set it?
Charge the fitbit and then connect it to your PC or Mac. When the fitbit has completed syncing, the time will be correct based on the computer time.
Apr 06, 2018 | Exercise & Fitness
Need the time reset on my fitbit
  1. From the Fitbit app dashboard, tap or click the Account icon ( ).
  2. Tap or click Advanced Settings.
  3. Tap or click Time Zone.
  4. Turn off the Auto option and select the correct time zone.
  5. Sync your tracker.
Help article: How do I change the time on my Fitbit device?
https://help.fitbit.com/articles/en_US/Help_article/1176
time reset on my fitbit Google Search
Mar 25, 2018 | Exercise & Fitness
How to set time on fitbit
There are some specific things you can do depending ion what Fitbit you have, but without knowing that, here is some general advice. Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order. Check if your device has the correct time before moving on to the next step.
1. Re-sync your Fitbit to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
5. Try resetting your Fitbit (specific instructions depend on which one you have).
Oct 20, 2017 | Exercise & Fitness
The time is wrong on my fitbit hr
Theoretically the Fitbit should keep the time updated though syncing, but there are some things that throw it off. I would try these steps in this order. Check after each step to see if you have the correct time before doing the next step.
3. Make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit in your Bluetooth settings.
Hope that does the trick!
Oct 17, 2017 | Exercise & Fitness
My Fitbit Alta is showing incorrect time. How can that be changed?
Hopefully one of those steps will get you on the right time, but if not, try resetting your Alta by doing the following:
Plug in your Alta in a USB (computer, or adapter) as you normally would to charge it. It should begin charging.
Press the button on your charging cable three times within eight seconds, briefly pausing between presses. (The button is on the end of the charging cable).
Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
After you see the logo you can unplug your tracker from the charging cable.
Oct 12, 2017 | Exercise & Fitness
My fitbit has the wrong time on it.nhow do i amend the time
Oct 07, 2017 | Exercise & Fitness
My fitbit is not syncing
My Fitbit suddenly stopped synching with my iPad and iPhone. It is fully charged and the lights show on my unit.
Sep 28, 2016 | Fitbit Flex Wireless Activity & Sleep...
I can't find my instructions. how do I correct the time on my fitbit charge?
    1. Editing your timezone settings
      1. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard.
      2. Choose Settings > Personal Info and find the Time section.
      3. Choose your timezone and select your 12-hour or 24-hour display preference.
      More items...
      Help article: How do I update my Fitbit settings? - Fitbit Help
      https://help.fitbit.com/articles/en.../How-do-I-update-my-Fitbit-settings Fitbit
    Feedback
  1. The time is incorrect on my tracker's display - Fitbit Help
    https://help.fitbit.com/.../The-time-is-incorrect-on-my-tracker-s-disp...
    Fitbit
Jan 03, 2016 | Fitbit Charge Wireless Activity Tracker...
The time on my fitbit is incorrect. How do I correct. Currently it registers 9:43, but, I'm on Eastern Standard Time.
    1. Editing your timezone settings. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard. Choose Settings > Personal Info and find the Time section. Choose your timezone and select your 12-hour or 24-hour display preference.Mar 10, 2015
    Feedback
Jan 03, 2016 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
