Question about Cell Phones
Connect phone to new computer - Cell Phones
  • uwbfritz Dec 29, 2016
    Hi Anthony Burns, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Activating android phone screen from computer without touching the phone
use ur second phone and connect it to ur computer with the android logo.
REMEMBER where the CONNECT button is on ur NEW PHONe.
Connect ur phone with the cracked screen.
When u plug it in a beep roughly memorize the touch moments u made on ur NEW WORKING touche screen android phone.
make the same motions.
see if the touch sensitivity still works
cross ur fingers hope it connects.
(Alternatively if that fails) take out the SD CARD from ur old phone. put it into ur new phone. use it to upload ur old files to ur computer.
Mar 16, 2014 | Cell Phones
I've just purchased a new windows 7 computer with
1) Download the USB driver for your phone here:
2) Install the driver and reconnect your phone via USB.
3) On your phone's status bar, choose the option "connect as a media device" to make sure the pc can now see the phone.
4) Disconnect the phone from the pc.
5) Now, to connect the phone as modem, reconnect your phone to the pc via USB.
6) Go to your android phone's settings, choose "wireless and networks, then "more," then "tethering & portable hotspot."
7) Check the box that says "USB Tethering."
It should be working now!
Sep 28, 2013 | Cell Phones
How to teather computer to samsung smart phone droid
You need to be more specific! Was your computer only connected to the internet threw your old phone? If so you need to set up the new phone and your computer to have the same matching connection information and passwords. It sounds like you may not know you need to configure your phone to allow a tether your computer to it and you also need to set your computer to the same information and configuration you set your new phone to.
Nov 05, 2012 | E-Machines eMachines Desktop PC
Transfer pictures to new phone
1) Connect your mobile to computer
2) Open My computer and check for a new drive which appeared after connecting the mobile.
3) Open the folder and Copy the Pictures from Photos Folder
Jul 29, 2012 | Palm Pixi Cell Phone
How to connect my xperia x8 as a modem to connect to my laptop to use internet?
you can connect it by data cable or wirelessly by bluetooth once it is connected to your computer open the program for your phone (it comes in dvd/cd with phone)
then select connect option to connect internet from your phone as GPRS or modem as you need
remember when you first time connect phone with computer it shows notification new hardware found and installs your device as standard modem also you can select your phone as modem in control panel also
further the same procedure to make new connection
good luck
Aug 20, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Basically. My phone isn't connecting with a computer / charging.
You may need a new battery. If a phone does not hold a charge, or does not charge at all often the problem is the battery and not the phone.
Jun 21, 2009 | Sony Ericsson V630i Cellular Phone
Need a new cable type CA-53 for my N90 mobile phone. HELP !
hi u can get a new usb cable to connect ur mobile to computer in any of the mobile accessories shop...
 better try to get a new cable or else u will face problem during transfer of medai files from computer to ur mobile..
Feb 08, 2009 | Nokia N90 Cellular Phone
Cannot detect device
Connect the phone while the computer is off. Power on teh computer and it should detect a new USB hardware device. You should then see two new drive designations. 1 for the phone's memory and teh 2nd for the onboard memory card if you have one installed. Remember for the first connection the computer must be off when you connect the phone.
Jan 20, 2009 | Apple iPhone Smartphone
Camera phone driver
you can download the Mobile Phone Tools Software from
Jun 26, 2008 | Motorola Mobility RAZR V3
Cant download pics from phone to computer no more...why ???
Disconnect the phone cable USB then open Nokia PC Suite (I presume you've got a Nokia N70) At the top of the PC Suite window go to Settings/Manage connections, tick the two bottom boxes, Serial Cable [CA 42] and USB cable, TWICE so as to highlight the Configure button.
Click OK, then follow the instructions to connect the cable to the USB then the other end to the phone.
It should now work if you're lucky, if not do a restart.
After restart connect the phone to the cable.
Give plenty of time for the icon on the PC to go green before clicking it to open PC Suite.
Feb 21, 2008 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
