Question about Celestron Optics
I have the Celestron NexStar 5se. When using the hand control and also when using the SkyPortal app I can move the telescope left and right but I cannot get it to move up and down. Can you help me?
3 Suggested Answers
SOURCE: The azimuth adjustment keys don't work
Send it back along with the hand controller describing the problem. Could be several things including a bad hand controller. If there is a local astronomy shop nearby take the scope there and ask to try one of the hand controllers in the shop and test it. If it now works you just need to buy another hand controller.
Otherwise send it in for repair
Posted on Jul 05, 2009
SOURCE: Celestron Nexstar 114gt telescope,hand controller lights up only
Do you have a fresh set of batteries in the scope? Better to use an outside 12 volt power pack with the Celestron 12 volt "cigarette" lighter cable.
This can be three things:
Low power
Bad cable from hand controller to scope.
Or a broken hand controller
Try fresh batteries first.
Posted on Dec 31, 2009
Celestron NexStar 8SE shows No Response 16 and No Response 17 errors repeatedly.
Reset the hand controller and reload the firmware. You will need a special cable available from Celestron to load the firmware. The software is available for free on the Celestron web site.
http://www.celestron.com/c3/home.php
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Aug 01, 2011 | Celestron NexStar 8i (600 x 203mm)...
I have connected the hand held remote control to me Celestron NexStar 80GTL and nothing happens. The remote will not power up. Don't know if the problem lies with the remote or is a more major...
Are the batteries fresh? You can also try a new hand controller cable maybe the one you have is broken which is a common problem.
Beyond that you can try to borrow another hand controller and try it. If none of these work, then you have a blown circuit inside the telescope. It will need to be returned to Celestron for repairs.
May 27, 2011 | Celestron NexStar 4 SE Telescope
I bought a used nexstar 130 Gt. The hand controller lights up and will move the scope, but will not display any information . Can this be fixed or do I have to get a new one? Thanks Lenny
First do a RESET on the hand controller --- also the b. Some of these scopes have a brightest adjustment.===rightness and contrast may be set too high.
The problem will be navigating the menu tree without seeing anything-- the menu tree is shown in the manual try to get to the reset by "touch". or to the contrast by touch.
Contact Celestron here is you continue to have issues with this:
http://www.celestron.com/c3/page.php?PageID=37
Jan 21, 2011 | Celestron NexStar 130GT (306 x 130mm)...
The Celestron Nexstar 4SE makes a weird cracking noise when you press the left or right arrows on the controller. I tried taking it off of the tripod, and it still will not rotate left or right, even if...
Is the AZimuth clutch locked down? Then either a gear is broken inside or the worm gear inside has slipped and is not engaing. You can return these to Celestron for repair, here:
Dec 26, 2010 | Celestron NexStar 4 SE Telescope
Sound like a gear inside is either broken or the worm gear is locked up. Celestron can repair this if you call them here:
Hi, Bought a used telescope with a GT mount. The polar adjustment will not go below 46 degrees without binding. The binding screw only turns 1/4 turn in each direction and appears to be binding the...
This scope does NOT need to be polar aligned --
Here is the manual:
http://www.celestron.com/c3/images/files/downloads/1228334587_nexstargt.pdf
This is an ALT AZ goto scope. Read the manual above. You use the hand controller to move the scope in Altitude and Azimuth(left-right).
You must align it on 2 stars in order for it to has successful gotos.
Aug 21, 2010 | Celestron NexStar 114GT (269 x 114mm)...
I have the Nexstar 8. It will not auto align or manual....
First do a RESET on the hand controller and make sure TIME, DATE, and SITE, are correct.
If this does not work then RE-load the firmware in the hand controller. If that fails contact Celestron customer service.
May 15, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
New batteries put in....It doesn't power up
Are you SURE you installed the batteries correctly? I once installed them with ONE battery reversed. !
Jiggle the cable to the hand controller, you might just have a bad cable. You can buy a new one from Celestron.
If you can get a 12 volt power pack and the proper power cable or the 110 volt power pack-- try it on direct power. If this is a new scope I would return it to the deal if these simple fixes do not work.
Apr 09, 2010 | Celestron NexStar 5 SE (300 x 44.45mm)...
Low power
Dec 31, 2009 | Celestron Optics
Jul 01, 2009 | Celestron NexStar 5 SE (300 x 44.45mm)...
Optics Logo
50 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
