Question about HP Office Equipment & Supplies
I have a paper jam. how do i clear the jam? thanks!
Hp fp4480 printer
  • 14 Answers
SOURCE: Paper Jam Error on HP 2015
For whatever reason the printer internal programming became corrupt showing that there is a paper jam. After checking the paper path and a quick can of air sprayed into the tracks, I proceeded to attempt a Cold Reset.
1) Remove the paper tray.
2) Remove toner cartridge.
3) Unplug USB.
3) While plugged in to power, turn off the printer, hold down the 'GO' button and power it back on. Continue to hold for more than 5 seconds but less than 15.
4) Reinstall the tray (be sure to check the paper level indicator is operating when you add paper to the tray. The lever should move up as it fills with paper)
Reconnect the USB cable (make sure you are using a thick USB cable and not a cheap thin one, very important. Make sure the printer is not plugged into a backup batter either) Never plug a printer into backup power.
I noticed that the computer did not recognize the device when connected which prompted me to contact HP support.
HP Support is shipping out Item # CE517AB - Font/DIMM Program for me to install in the printer to most likely reinstall the firmware.
I will post back if this works to flash the firmware or just waste some time.
Posted on Aug 06, 2008
  • 80 Answers
SOURCE: How to Clear carriage jam
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Posted on Dec 04, 2008
SOURCE: HP 7680 paper jam
I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
Posted on Apr 10, 2009
  • 385 Answers
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Posted on Apr 16, 2009
  • 3085 Answers
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ... Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ... Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ... There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ... > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
How do you remove paper tray on hp photosmart 8250 printer to clear paper jam
Hi we2halls,
You may want to try the procedure on this link to help you clear the "Paper Jam". It includes detailed instructions and some illustrations.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | HP Photosmart 8250 InkJet Printer
Printer says to clear paper jam and press OK there is no paper jam
If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not
in the rear rollers, check the top door.
To clear a paper jam from the rear door
1. Turn off the HP All-in-One.
2. Press in the tab on the rear door to release the door. Remove the door by pulling it
away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Page 148 of manual here will show you more info as well as photos on hoto.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 01, 2010 | HP Photosmart C8180 All-in-One InkJet...
Paper jam
Dear sir,
i am giving u setp to solved your problem,
Step one: Remove any loose paper.
Step two: Clear the jam from the back of the All-in-One
Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
After clearing a paper jam incorrectly
Please check all places and follow all the steps here:
Thank you
Feb 05, 2010 | HP Officejet 5610 All-In-One InkJet...
Paper Jam, Clear jam
This may be caused by a dirty sensor. Disconnect power supply, open the printer and clean everything. You may use toilet paper. Be careful not to leave fragments of toilet paper inside the printer.
May 06, 2009 | HP 5510 4-in-one Printer
False paper jam on HP Office Jet V40
hp officejet v40 indicates a paper jam and it is cleared nothing
Apr 04, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
Paper jam
here try this guide to clearing Jams supplied by HP
Clearing Paper Jam Guide
I hope this clears your problem :)
Apr 02, 2008 | HP Photosmart C4180 All-In-One InkJet...
Ben Johnson
