My sumsung S111 won't switch on the battery is fully charged so it's not that
3 Suggested Answers
emissionwiz
  • 77544 Answers
SOURCE: runs on battery fine, starts
Hello
It sure sounds like a defective battery to me (one or more dead cells in stack), it takes more voltage to boot up than run once booted, so if the battery is failing that would give the symptom you have. I suggest you have a local Radio Shack test the battery.
Posted on Aug 12, 2011
  • 6771 Answers
SOURCE: my battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Posted on Mar 07, 2012
Iloilo city
try a different battery or use an external charger.... the battery could be faulty, or the camera charge function could be faulty.... a different battery will help you decide where the problem is.
Apr 05, 2014 | Nikon Cameras
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Battery not fully charging
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 04, 2011 | ASUS Computers & Internet
I am trying to charge my cars battery but I am not sure where to put the 3 way switch.
Best solution is to use the Auto mode, since the unit will monitor the battery, and automatically switch to trickle charge when the battery is full. In the Auto mode, it won't overcharge the battery.
Feb 28, 2011 | Schumacher 10 Amp Fully Automatic/Manual...
Help, Toshiba Satellite M35X-S111 laptop has stoped charging the battery. The light stays orange no matter how long its pluged up. You have to move the plug around to get it to power, I had it checked by...
what is the age of the laptop?
How old is the battery?
Try this...
1. Check/test the battery
2. Test the charger.
One of these seems to be the problem...
Jeff
Oct 25, 2009 | Toshiba Satellite M35X-S111 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
