SOURCE: skagen ladies watch
izzi, I assume you have a snap back back that won't snap back in place. I had the same problem with a Timex EXpedition. The solution should be similar. See my post" http://www.fixya.com/support/t190459-watch_battery_replacement and also the site I reference there. http://www.online-batteries.co.uk/whichbattery.shtml Good luck, Richard
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
SOURCE: Can't find replacement mesh watch bands for Skagen watch
try this website its directly to skagen! they can replace your band.
http://www.skagen.com/service/orderWatchBandParts.fx
SOURCE: Where can I buy replacement
Try this link:
SOURCE: My skagen watch have just
if you had it for awhile then it probably is the watch battery. It should be fairly inexpensive any where from 7-12 dollars to replace the battery. This can be done in most jewelery repair stores or jewelry stores. You can also go to places such as fast fix that are located in strip malls and malls all around the US.
http://www.fastfix.com/
check to see if there is one near you. If not any jewelry store would be suffice.
