Question about Onkyo Audio Players & Recorders
My onkyo tape 2 monitor button will not turn off. When I hold it down it it changes from tape 2 to tape 1 but monitor stays on
  • 109 Answers
SOURCE: X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
Posted on Jun 01, 2008
SOURCE: connecting an onkyo m282 to a vintage (1994)onkyo tx905 receiver
I have found the solution.
Using an Audioplex SPKCNV Speaker Level To Line Level Converter should resolve the connection issue.
Posted on Jun 20, 2009
SOURCE: samsung bl103
Samsung bl103 when i turn on the camera it stays on about 3 seconds beeps 3 times then shuts off. it has new batteries so that's not it.
Posted on Aug 21, 2009
  • 19 Answers
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Posted on Jan 18, 2010
SOURCE: HP DV9410US laptop turns on for 1/2 sec and shuts down.
Yes, there is a solution to this issue. Go to: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&product=3308892&docname=c01087277#c01087277_identify
and look up your p/n # on the back of your laptop. If it matches, just call HP at in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week. Why they never had a recall is beyond me. I have had two of these replaced one DV9743us and one DV9410us. There is a catch however... HP will only replace this free if it is within 24 months of the start of your original warranty. If it is out of the Enhancement warranty time frame, they will replace the Motherboard for $259 (included shipping, parts, and services). Not bad for what they are doing. Should there be a recall? YES~!!!
Posted on Mar 08, 2010
Why no sound on Onkyo TX-8011
Hello Randy Risher, At this point being that you are not getting any audio from any source, I would suggest a reset. To do this press and hold down the Tape 1 input on the receiver. While holding that button down press the Direct Tuning button. You will see the word CLEAR in the screen which indicates that you have done the reset correctly. If after the reset the audio does not return then the unit would have to go in for service. However, being that it is very old (2004 model) it's not guaranteed that there are parts available for the receiver. I would call our product support team at 800-229-1687 x3 to see if your receiver is eligible for trade in program. Thanks, FJD
Apr 14, 2016 | Onkyo TX-8011 Receiver
How to hook up a DBX 231 to an Onkyo P301
you will need 4 1/4 inch male to rca male cables, use tape monitor (tape out to line in on eq, line out from eq to tape in on receiver, make sure both buttons that control line level on the back of the 231 are set for -20dbv press tape monitor to use eq, turn off to bypass it.
Mar 06, 2014 | DBX Audio Players & Recorders
Onkyo tx-sr503 volume too low
If the volume is too low on all inputs, even when you turn up the volume, first turn down the volume completely and check to see if you have a tape monitor button pushed in. If you do, disengage the button, then turn the volume back up. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 27, 2013 | Onkyo Audio Players & Recorders
Monitor buttons do not work right``````````how to get another monitor ?????
Do you understand what that Monitor Button means?
Only Tape 2 can be monitored.(Page 24, diagram on page 25)
http://www.retrevo.com/support/Onkyo-TX-8522-Receivers-manual/id/469ci860/t/2/
Jan 12, 2011 | Onkyo TX-8522 Receiver
In my Onkyo receiver, it normally just says Video but for some reason it says Video T2 On and there is no audio coming out. Any ideas?
T2 IS selection for EQ. ( TAPE MONITOR LOOP )Hold the T2 button down long enough and it will switch it to OFF. Karl
Jul 29, 2009 | Onkyo TX-8522 Receiver
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
Apr 29, 2009 | Onkyo TX-DS838 Receiver
Power on but no tuning or sound from other sources
Check for "Tape Monitor On" button. According to Onkyo's web page "Press and hold the tape button for two seconds allows the tape and MD sources to be switched - Also try the speaker A/B switch. - Check back for further assistance - The web page for your operations manual can be found at...
http://www.us.onkyo.com/download/own_manuals.cfm?cat=Receiver
Then select your model.
Hope this helps
Len
Mar 02, 2009 | Onkyo HTR500 Receiver
Center screen
I figured out that the monitor has to be reset. I was able to figure it out. Turn off the monitor, hold down the + - buttons together on the monitor & turn the monitor on while holding the buttons down, you will see a message on the screen that the monitor is resetting, you can let go of the buttons & the monitor will be reset to factory settings.
Tom Z
Sep 19, 2008 | Kogi L7CH Monitor
TX 8410 Onkyo no sound
Well, I'm sure you've either fixed the issue or gotten rid of the unit by now, but anyway... perhaps the speaker selection was accidentally switched (A or B), or my personal favorite: "Tape 2 Monitor" was turned on. Even if you select something else, you'll still see "Tape 2 Monitor" displayed on the LED display. Hit the button again and it will go away and your sound should return.
Jun 05, 2008 | Onkyo TX-8410 Receiver
No sound/can't get rid of "video 1" or "video 2"
I had the same issue... It turns out that there is light on the screen under the A and B speaker lights which said T-2 Monitor. This meant it was sending the sound out to the tape # 2 monitor... Hit the Tape 2 button and you are back in business...
Nov 02, 2007 | Onkyo TX-8511 Receiver
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
