SOURCE: time date
i know i set this model before but i recently tried to again and it didn't work right for the time for some reason... but i do remember that you flip the middle switch to rate set, the you put in the date 12.10.08 seperated with a "." then you hit the time date button once. then you do the same with the time, hours(militarytime).minutes.seconds all seperated by a period I.E if it were 1:30 PM you woud put 13.30.00, then you hit the time button again.. the date and time should be set, might have to do it in the opposite order... but i know that is generally how its set
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
SOURCE: Need a replacement ink roller replacement for
Part# IR40T
http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
Thanks
