My washer machine sharp fuzzy logic control 6.5kg have trouble error can i fix it?
  • 1294 Answers
SOURCE: LG Fuzzy Logic won't drain out the water
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 21, 2007
SOURCE: LG Washer LE Error
Solved LE error for my WM1832CW by replacing Hall Sensor. Bought part 5016501KW2002A for $Cdn 26 at Sears parts store. Thanks to TC at for instructions:
1 Open rear panel. Take 17mm nut off (it's the only one)
2 Pull off what looks like a goofy hubcap (it's held by magnets)
3 Unscrew the six 10mm bolts and gently lower the coils
4 Remove and replace the Hall Sensor (plastic comb looking thing)5 Plug in the sensor and re-install the coils and cover.
30 minutes for me.
Test spin cycle if desired by following chart on page 19 of service manual at
(note lower models skip step 10 (heater test).
Hall Sensor Part labelled as K351 in diagram on page 41 of service manual.
Posted on Jun 30, 2009
  • 3 Answers
SOURCE: My NEC Fuzzy Logic 6.5kg
I had the same problem, When calling a repair shop I told the mechanic it was coming up LE on the display. He told me it was a lid error. Which made perfectly clear sence. I checked the lip of the lid and there it was, a piece broken off where it hits the saftey switch. (my switch was on the left). So check the strike plate on your lid. You may have to screw a piece of alaminium angle to replace it. Or replace the lid.
Posted on Nov 24, 2009
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
  • 6277 Answers
SOURCE: washing machine stops after wash,
LG's 'OE' means 'drain (Output) error.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 16, 2011
How do i fix an LG 5.0 fuzzy logic washer that keepscoming up with a DE error?
The DE error indicates a Door Error condition....check out the door for any distortion or misalignment with the door latch.
Check the door latch assembly for continuity and if faulty replace the switch.
Mar 24, 2015 | LG Washing Machines
Fix LE error for LG washer
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Oct 07, 2014 | LG WT5070CW 4.7 Cu. Ft. Ultra Large...
LE in display
Hello, page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
How to reset eprom for PE error
Hi, PE error code means there is an pressure sensor error in your machine .You need to check pressure it will be giving incorrect indication . Pressure switch is faulty you need to change it . Procedure for changing is : 1.Power off the machine remove backcover and top cover. 2.The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. 3.It generallysits just under the top cover.
Apr 08, 2010 | LG WFT1071TP Top Load Washer
LE sighn on NEC washing machine
Generally LE is as you said a load error. This can refer to an unbalanced load in the machine. You should try to redistribute the clothes to even the loadThe addition of a P.I error code indicates it is having problems loading the programmed wash instructions.
The fuzzy logic is a form of artificial intelligence that controls the preprogammed operations of the machine and warns of wring usage.
If redistribution of the load does not work unplug the machine from power and leave for a few hours. Then replug and turn on.load with a few items only and set the unit to wash ...
Aug 11, 2009 | Washing Machines
My NEC Fuzzy Logic 6.5kg Washer keeps coming up with LE in the timer box. It also makes a high pitched noise with it. I suspect it is some sort of error message? The washing machine is not dispensing...
Jul 02, 2008 | Washing Machines
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
