Question about Home Security
How to default a 8ch provision dvr to factory defaults
XRAYRON
  • 156 Answers
SOURCE: Factory Default Reset Procedure
Hold the reset button in for 10-15 seconds... Now its defaulted back to factory and the user name and pass will both be admin
Posted on May 07, 2008
SOURCE: Need to reset back to factory default
hello I am using PANASONIC KX-T308 , and forgot its pasword. I want to reset its password back to factory default i.e. 1234. can some one help me ?
Posted on Sep 17, 2009
SOURCE: restore factory default on HP mini laptop.
Hey guy's stop wasting your time on asking stupid questions! The hidden system recovery for HP mini 110 is this~
1st - Make it sure the Adapter and the Battery is already attached on your laptop.
2nd - Press the power button to turn it on.
3rd - When you see the HP logo on screen just easily press F6 rapidly.
4th - Stop pressing the F6 when the "Windows Starting" appears on.
5th - After that easily read all the useful instructions on how to system restore your HP mini 110.
Note: Don't mind the Dell, F10 or anything just do this ok?
Tech.Support ~ jhayr
Posted on Jul 19, 2010
SOURCE: how to reset samsung star to default factory
pls help me how to restore samsung mobile phone s5233w factory setting code
Posted on Nov 30, 2010
  • 53 Answers
SOURCE: factory default
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Feel free to get instant online router/wireless router support at http://www.vtechsquad.com/wireless-router-support/ to fix D-Link router/wireless router issues.
Posted on Oct 23, 2012
I purchased a NIGHT OWL modelxhd50288p 8ch v 2tb 5mpcam system and forgot pw and dvr is locked how can i reset it
hello friend. idont known much about this night owl model dvr.but i can suggest small technique which we use i n chinese dvr.open the dvr look for 2030 small battery fixed in the board remove it .start your dvr reset to factory setting once then insert the battery again.i hope your dvr is ready.
Oct 25, 2017 | Night Home Security
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
Sumvision 8ch dvr forgot admin password and can only log in on admin. Tried codes 123456, 000000, 111111, 999999, 1234, 4321 the last two were tried when the battery was removed please help
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is '4321'., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Mar 28, 2015 | Computers & Internet
How can i rest a password on my truvision dvr30
The TVR 30 is shipped with one predefined user for the system administrator and
seven predefined standard users. The default system administrator logon uses admin
as the account name with a default password of 1234. You can modify the admin
password but not the admin user name. The seven predefined standard users are
labeled User1 to User7 with a default password of 4321 and level 4 access. The
administrator can customize the seven standard users and define their privileges.
Use the Users screen (shown in Figure 20 below) to manage users.
Note: When accessing the main menu for the first time, the system lets you pick
either an admin user or a regular user (User 4) by default. If you select User 4, enter
the initial default password of 4321.
Dec 28, 2014 | GE TRUVISION DVR 30 8CH 2TB
Qihan dvr super password
Forget the DVR password, how to generate a new one with software ...
www.hkvstar.com/.../forget-the-dvr-password-how-to-generate-a-new-one-with-softw...
Nov 4, 2013 - If you forget the DVR password, you can use the password generation software to get a new super admin to unlock the DVR.
Reset DVR password to Factory default - • CCTV Forum
www.cctvforum.com/viewtopic.php?t=39460
Jan 26, 2014 - 15 posts - ‎4 authors
I have a DVR shown below and I am not able to reset the system to the factory default. It is an 8 ch standalone, unbranded, no make or model ...
How to - Zmodo DVR Resetting to Factory Defaults - YouTube
? 0:46
https://www.youtube.com/watch?v=rT-cUgWbHQM
Sep 24, 2009 - Uploaded by CCTVHotDeals
This video shows how to reset your DVR to factory defaults. ... Reset PasswordDVR H.264,AHD, With Super ...
CCTV H264 DVR password reset superpassword super password ...
https://dashcamtalk.com > Home > Forums > General Forum > Off Topic
Jan 2, 2015 - 12 posts - ‎7 authors
I was searching on internet for this problem because I set the password one year ago, I forget it and I want to reset the password. I have a ...
How to reset password ?
support.qube.asia/127247-How-to-reset-password-
STEP 2- Open the cover of the DVR. STEP 3- Remove the CMOS battery. STEP 4- Power On the DVR. STEP 5- Enter a password. Username: As given.
[PDF]Qihan NVR manual
www.riasztobolt.hu/pictures/down/en_tmanual_quihannvr.pdf
Support modifying the user's authority and password. Subdivide the authorities (preview, ... DVR: Digital Video Recorder. IPC: IP Camera. IP PTZ: Network High ...
Aug 13, 2014 | Home Security
Reset password samsung SDR-5102
By default, initial ID and password are set to "admin", and "4321
Jul 30, 2014 | Samsung 8ch Dvr 4 Camera System 19" Lcd...
Dvr ja7204
Restoring Default Settings
To restore factory default settings to your DVR:
1. Enter the Factory Default menu, by going to Main Menu > Maintenance > Factory Default.
2. Select the OK button to restore factory defaults or select the Cancel button to return to the previous menu.
Note: Network information such as IP address, subnet mask and gateway will not be restored.
hope thid helps. and you can also try removing all power from unit if it does not have inturnal battery. if it does have an internal battery after removing all external power you will have to remove battery to completely reset. Note the latter suggestion will void warrenty if you have to open the unit to remove the battery.
GOOD LUCK :-)
Jun 14, 2014 | Computers & Internet
Anko 8ch standalone network dvr super password?
Please help me .
I 'm lost my pasword .I need a super pasword.
Thank you so match.
Dec 21, 2012 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Home Security Logo
79 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
