First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx.
Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
