Question about Health & Beauty
Chair ! Model 60-7000M footrest will not close.
Drive enigma SD2 angle of arms on footplate not far enough forward
Footrest/legrest come made with different angles. Their are standards of 60, 70, 80, and 90 degree angles. The lower the number the more the footrest/legrest stick out from the chair. You would need to put an angle gage on the angled tubing and get your angle before knowing what you might be able to get. There are also adjustable angle legrest that can be adjusted as needed without using any tools.
Oct 12, 2014 | Health & Beauty
Why is the footrest so difficult to lower?
Some recliners are just designed that way - my wife's chair is nearly impossible for me to close.
Jul 29, 2014 | Simmons Apollo Jumbo Cuddler Recliner
Install foot rest
If you have the swing on footrests or legrests for a Pride Jazzy series with 2-pins on the hanger brackets please be sure that the hanger brackets are properly installed on the chair with the pin side of the bracket facing to the outside - not inside. To put the footrests on - align the lower pin first with the footrest at a 45 degree angle to the outside of the chair. Then align up the top pin and lower the footrest onto the hanger bracket. Rotate the footrest towards the front and lock the cam lock in place. If the cam lock has a handle that is bent it will interfere with the lock and need to be replaced or bent back in place.
Nov 13, 2013 | Pride Jazzy 1113 Power Chair
Simmons rocker recliner footrest spring placement
my spring on my footrest on my simmons recliner broke,when I replace it, where does it connect on the chair ?
Oct 24, 2013 | Simmons Rocker Recliner
How to choose a comfortable camping chair?
In case you going on a trip with your car or with a RV the weight of the chair don't come into consideration. You should pick a chair with drink holders, footrest, armrests, back padding and even with a canopy which can turn out to be very handy.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
How to close the Cosco Flat Fold High Chair - Barnyard Buddies by Cosco
Pull the tray and the footrest up mind your fingers please give thumbs up thanks
Jul 03, 2011 | Cosco Juvenile Flat Fold Highchair Circle...
I have an invacare Pronto M51 Surestep power chair from 2008. I need the swing out foot rests in the red color. Can someone help me with this situation and what would they cost-thank you
If you have had swing away footrests on this chair you can replace them with model PHW93 and must ask to get them in red when you order them from a wheelchair store. If you dont know where a store is that sells Invacare products, call Invacare customer service at 800-333-6900.
Mar 08, 2011 | Invacare Pronto M51 Power Wheelchair
I need foot rests for my whell chair
I would recommend let them know your make and model and they should be able to get you the footrest you need.
Thanks hope I was able to help.
Jan 20, 2011 | Everest & Jennings Health & Beauty
Need a Footrest for Pride Jet 3 ultra
The footrest for this power chair comes in a wide variety of styles and configurations. To duplicate the correct footrest it is best to go by description of hanger, extension tube length, and footplate style or simply have the manufacturer run the serial number. The serial number will lock in the exact footrest configuration delivered with the wheelchair. With the SN a dealer can order individual parts that will fit and work correctly. This will ultimately will save you time and money. Hope this helps.
Nov 25, 2010 | Pride Mobility Products Jazzy Select 14
Health & Beauty Logo
56 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
