Question about Sewing Machines
Where does the tension spri ng go on my babylock 1550 bobbin winder
  • Sewing Machines Master
  • 12,526 Answers
It may be worthwhile to purchase a new bobbin case for your machine. Trying to re-attach the spring will most likely cause the spring tension to change making it difficult to get the tension correct. Bobbin cases do wear out and really are not all that expensive to purchase. A lot of sewists keep more than one bobbin case on hand so they can adjust a specific case to accommodate the tension for specific thread weights.
Posted on Dec 29, 2016
Manuel for baby lock 1550
Sewusa claims to have the manual for $10 plus shipping. See http://www.sewusa.com/Sewing_Machine_Manuals/Babylock_Manuals/BL_1550_Instruction_Manual.htm . This other site, http://www.sewingmanuals.com/Sewing_Machine_Manuals/babylock.htm , also claims to have the manual.
Unfortunately, Babylock no longer has the manual for the Companion 1550 (BL1550) for download. It's unlikely that any Babylock dealers will have the manual. However, dealers will often provide manuals if they have them for a small fee.
I hope this helps.
Apr 08, 2018 | Baby Lock Sewing Machines
Can someone tell me where to get a free downloadable Babylock BL1550 sewing manual.
http://www.sewingmachinemanual.net/Sewing_Machine_Manuals/Babylock/Babylock_BL-1550_instruction_manual.htm
Jul 03, 2015 | Sewing Machines
Babylock frozen tight its a eklure plus only used 6 time I've check bobbin cade changed needle although it was fine shut it off and turn it on. Bobbin winder on right side. It threw up a safety warning...
Sounds like it's time for a visit to the repair shop Babylock Ellure
is a fairly nice machine, it will be worth it...
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 23, 2014 | Sewing Machines
Bobbin winder doesnt work
The bobbin winder tires on most of the new lower to medium end brother machines have a tendency to sort of melt. I honestly don't know what causes it, but basically the rubber ring that rides the handwheel and causes the bobbin winder to turn will liquify and drip off the bobbin winder and then re-solidify. It would be best to take your machine to a repair shop, to get the tire replaced and to have the old tire sludge cleaned out, though if you are adventurous, you could try it yourself. You can order a tire at the link I've provided, but most sewing machine repair shops can get you one as well.
Bobbin Winder Tire Babylock Brother X55238051
Jul 03, 2014 | Brother CS6000i Computerized Sewing...
Getting the cover off my brother cs 80. all screws have been removed and the cover comes off partially. I seems to be stuck at the turn wheel, like something is holding it fixed.
I had the same problem when opening my machine. The problem is a screw underneath the bobbin winder area. Pull the bobbin base off and then gently pull up the bobbin winder assembly from under the front cover. You will see a screw in the corner to remove so that you can complete the task. I had to purchase a service manual and then I had great success with replacing the bobbin winder "tire" (Bobbin Winder Tire, Babylock, Brother #X55238051 at sewingpartsonline.com - $3.99!!)
My bobbin winder works like a charm now. Sewing Parts Online Search
Sep 09, 2013 | Brother CS-80
What's your problem?
if the bobbin thread is winding around the bobbin winder spindle then
the bobbin is not sitting correctly on the bobbin winder spindle,,
the bobbin (metal or plastic) should lock in on the bobbin winder spindle
& the the thread should be around the bobbin tension guide
Apr 04, 2012 | Sewing Machines
When winding a new bobbin, the bobbin itself is breaking in two. (splits in half, the top and bottom split apart). It seems logical that there is too much tension perhaps. It happens almost at the end...
There's really no way to increase the bobbin winder tension. Check to see that you have it threaded correctly for bobbin winding. There should be just a little bit of drag on the thread as you pull it over to prewound it on the bobbin.
May 03, 2011 | Brother PE-150V Computerized Sewing...
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Tension settings for the babylock sewing machine
I found that the tension setting of 1 worked. The main problem was the machine had thread wound around behind the bobbin. I had to take the plates that are under the foot out, clean out the thread, oil the machine and use a spool of thread that had more weight than the little spool I was trying to use.
May 15, 2009 | Baby Lock BL1556
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
