Question about Elite Health & Beauty
Go go elite traveller only goes one mile before batteries expire. New batteries fitted. Same problem. New charger used. Same problem. Any ideas?
  • Elite Master
  • 1,049 Answers
Hi if the batteries r new & scooter is still no good maybe the batteries have been on the shelf to long without being charged when BATTERIES r left to discharge a coating forms on the cells when this happens the battery will never recharge properly go on to E/BAY & BUY A BATTERY LOAD TESTER THIS WILL GIVE U AN ACCURATE TEST ON YOURE BATTERIES CONDITION COST $35 , cheers...
Go go elite traveller only goes one mile before ba - 26417744-0cfjupowo51kh4olmbqxclmy-4-0.jpg
Posted on Dec 30, 2016
Who installed the new batteries? There could be a loose
connection or a disconnected plug to the controller when
the batteries were swapped out.
Jun 29, 2015 | Pride Mobility Products Go-Go Elite...
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
Pride travel scooter cut s off
This is usually due to the battery "jumping" off the contacts when you go over a bump in the pathway. Put a RUBBER door stop between the battery and the seat post. This fixed mine for all but the huge potholes. Had this fix for 4 years
Aug 04, 2012 | Pride Mobility Products Go-Go Elite...
We have a 11 month old elite traveler scooter. The battery will not take a charge. We have had no previous problems. Any suggestions?
I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
May 19, 2010 | Pride Mobility Products Go-Go Elite...
The airline broke off the key in the scooter
Your local pride dealer should be able to supply a new key. The key that fits the GoGo Elite Traveller is the same key that fits the whole of the pride range of scooters.
Feb 17, 2010 | Pride Mobility Products Go-Go Elite...
My go go elite Scooter will not work. its only just over a year old. it's not been used for a few months. When put on charge the charger shows its fully charged. When the scooter is swithched on the volt...
It may still be under warranty.  What kind of reading did you get from the batteries? If they are below 12.0 volts they may have a poor memory. If you leave a chair un-charged for a long period of time the batteries can discharge to a very low level. The charger cannot bring a battery up from 11 voltsDC. You will need a slow car type charger or new batteries.
Mar 19, 2009 | Pride Mobility Products Go-Go Elite...
Palm TX travel charger problem
It is an issue with the slot on the device, however you can charge the device using the Sync cable, it is the safest way to charge the device.
Dec 01, 2008 | Palm TX Handheld
Health & Beauty Logo
Top Elite Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Jeff Tilburn
Jeff Tilburn
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
