Question about Samsung Televison & Video
I have a Samsung WA13Vs toploader washing machine after the washing and rinsing cycles it does not spin, please help.
Gladys M
    Top Expert:
  • Samsung Master
  • 49,215 Answers
Sadly we can only suggest fixes from here . It might be the control board or the motor . only a repairman with the capability of hands on can tell you for sure
Posted on Dec 29, 2016
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
My topload Roper washer cycles fine but stucks in rinse stage. It makes a noise on that stage. I manualy put it in spin mode (skipped the rinse) and it works from there. Please help.
Your timer is bad. There must be a pause in the timer for the neutral drain transmission to lock in.
No Pause.
No Spin.
To double check this,when the timer gets to the Spin cycle, open then close the lid.
If it starts to spin at that point the timer is bad.
Jan 09, 2011 | Roper Washing Machines
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Jan 16, 2009 | Samsung SW62ASP Top Load Washer
Whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Nov 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Televison & Video Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
