How do yo connect a kenwood r-42l intergrated amplifier to a ge-420 kenwood graphic equalizer
  • 319 Answers
SOURCE: connect a kenwood amplifer to a graphic equalizer
There are several ways to hook up a EQ to amp. If you have a tape monitor unused, you can plug tape-in of amp to 'out' of EQ.
Plug tape out of amp to 'in' of EQ (both channels). When you engage monitor on amp, EQ will work.
Posted on May 30, 2008
SOURCE: Kenwood stereo B-B5 Power Amplifier/Graphic Equalizer
Replace capacitor 110 (47uf 25v), it fixed my problem, should cost about 25 cents and take about 1 hour of your time :-)
Posted on Jan 06, 2009
SOURCE: Kenwood B-B5/B7 Power Amplifier/Graphic Equalizer
Change the Capacitor C110 (47FU 25v) I found this solution on another post somewhere and it has worked on mine too.
Posted on Jan 16, 2009
  • 102 Answers
SOURCE: owners manual for my kenwood kgc-9400 graphic eq i want to inst
download from Kenwood's website
Posted on Mar 12, 2009
caroldon
  • 17130 Answers
SOURCE: how to wire up kenwood ge-760 graphic to my
First of all connect the source, the tape or the DVD, to the input of the equaliser, use the output to connect to the AUX of the amplifier. make sure that the L&R are not crossed over. In case your amp has an in and out of the preamp section use then connect the source to the amplifiers input specified for the source like tape or DVD or TV and use the preamp output to the equaliser input and the output of the equaliser to the input of the main ampflier. Now the bass and treble of your amp can be set to the mid point - 12 noon position and use the boost or attenuation according to your choice of music. hope you find my advice helpful. Good day
Posted on Jul 21, 2010
Can i use a graphic equalizer with a yamaha as-500
My Yamaha Equalizer is Model GE-30. Review the manual for this unit and on page 3 you will see the connection procedure "Line Out" on the equalizer to "tape deck in" on the amplifier. In the case of the A-S500 user manuaI on page 5, I used the "line 3 " also identified as "tape deck" to connect the equalizer.
The front control(s) from page 2 on the A-S500 manual are then set :
Control(5) input selector set to Line 3 (Graphic Equalizer)
Control(8) REC OUT selector to CD (for CD), line1 (my blu-ray player, or tuner (my DVR/tv)
The only thing I lose is "PURE DIRECT" does not fuction if the equalizer is on, otherwise;
I simply set Control(5) input selector swith to the desired input source, the equalizer no longer
functions and "PURE DIRECT" can now be used.
The rest of the tonal controls for bass, treble, balance, and loudness work as they should.
Jan 29, 2013 | Yamaha AS500 Amplifier
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Sep 27, 2008 | Kenwood Audio Players & Recorders
How to connect kenwood GE 52 graphic equalizer to my sony str-DE345 any idea , please help me.thanks.I tried many combination but didnt work.
An EQ usually plugged between a preamp and an amplifier. You have a receiver. There's no connections that will let you do that. The only thing you can do is between a source(ie: CD) and the receiver. The CD will go in the eq and out of eq to cd input on the receiver
Sep 03, 2010 | Audio Players & Recorders
How to wire up kenwood ge-760 graphic to my
Jul 04, 2010 | Kenwood Audio Players & Recorders
How do i connect them
I connected the red & white audio leads to the line out sockets on the equalizer and connected them to the tape rec sockets on the amp..
May 29, 2009 | Kenwood Audio Players & Recorders
Kenwood A-97 Sound gone poor
It sounds like the amplifier is going. I remember when I accidentaly crossed wires, the amp did the same thing, then one day it shut off. It wasn't the same amp, but it doesn't matter, it sounds like the amp is on its way out. :/
If you still have the warranty, I would have them take a look.
Mar 24, 2009 | Kenwood VR-405 Receiver
Connect a kenwood amplifer to a graphic equalizer
May 28, 2008 | Audio Players & Recorders
Kenwood stereo intergrated amplifier a-76
The only tricks to power up again are this:
Amp to Equalizer : Use the "Connector " of the Amplifier - IN and OUT and connect them to the Line IN and Line Out of the equalizer;
All modules: Use the system control cable like in serie, for example the lowest connects to the above and from thsi one to the other above and so on;
Regarding Power: both CD, Deck and Tunner have different colors to connect to the Amplifier power source, you can't miss it;
Audio Cables, just follow the IN and OUT with correct colors and you are done!
Rgds,
TrepaTrepa
Feb 21, 2008 | Audio Players & Recorders
Open Questions:
 Grubhead
Grubhead
