Question about Sewing Machines
My tension spring came off my bobbin winder on my babylock 1550. cant figure out how to put the spring back on
2 Suggested Answers
99rannellis
  • 10279 Answers
SOURCE: where does the tension spri ng go on my babylock 1550 bobbin winder
It may be worthwhile to purchase a new bobbin case for your machine. Trying to re-attach the spring will most likely cause the spring tension to change making it difficult to get the tension correct. Bobbin cases do wear out and really are not all that expensive to purchase. A lot of sewists keep more than one bobbin case on hand so they can adjust a specific case to accommodate the tension for specific thread weights.
Posted on Dec 29, 2016
Where does the tension spri ng go on my babylock 1550 bobbin winder
Dec 29, 2016 | Sewing Machines
The bobbin thread on my Juki DDL-8700 is loose and bunching up. I have messed with the tension on both top and bobbin and I cant get it tightened up. Please help!
Hello Lacinda have a good day to you concern loose or missed stitches please check next: 1-try to change bobbin case with new one. 2-check timing between needle and hook by -make needle bar at lowest position and you can see two mark line at needle bar. -bring the needle bar at second line from down side then check the flat part from needle comes with tip of hook ( if yes means timing is OK , if not means you need to adjust the hook timing . 3-check the ginger guide for hook try to move it foreword or backward to pass thread smoothly. if this is helpful OK if not please send email, i try to do the best to help. best regards ASHRAF ABOZID CAIRO - EGYPT aabozid@hotmail.com
Feb 24, 2015 | Juki DDL-8700
How do I fix my bobbin winder?
1. Take the top off.
2. Check to see if the bobbin winder has pressure as you move it back and forth. There should be. If not then check for a spring connected to the bobbin and reset it. There will be some kind of post to hook it to.
3. Place the bobbin winder in the "off" position and put the top lid back on.
4. Without putting the screws back in move the bobbin winder to the "on" position and to the "off" position.
5. There should be pressure either way you move the winder.
6. Loosen the hand wheel handle.
7 With the bobbin winder in the "go" position use your foot pedal to make sure it revolves.
8. Replace the top.
Dec 01, 2014 | Sewing Machines
How to put string into the shuttle
I take it you have a shuttle with a bobbin inside. Remove bobbin and attach it to the bobbin winder by the balance wheel, wind bobbin and while holding shuttle point downwards drop the into the shuttle, pull thread down to the bottom of side slot and then straight up under tension spring, load shuttle back into machine pointed towards you tension screw up
Feb 12, 2014 | Sewing Machines
When winding a new bobbin, the bobbin itself is breaking in two. (splits in half, the top and bottom split apart). It seems logical that there is too much tension perhaps. It happens almost at the end...
There's really no way to increase the bobbin winder tension. Check to see that you have it threaded correctly for bobbin winding. There should be just a little bit of drag on the thread as you pull it over to prewound it on the bobbin.
May 03, 2011 | Brother PE-150V Computerized Sewing...
How to fix bobbin winding
. Put the spring on the hole that the bobbin winder fits into. Now put the bobbin winder in, but don't tighten the screw- just turn it once or twice. Put the straight projection of the spring on the right side of the bobbin winder. Start to tighten the screw. Before you get the screw too tight, pull the downward projecting side of the spring over the housing of the machine so that it is pressing on the inside of the machine creating a push to the left. Center the circular part of the spring underneath the screw and the bobbin winder and tighten up.
Jul 15, 2009 | Euro-Pro 473
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Jul 29, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
