Question about Sewing Machines
My machine keeps skipping stitches. I have had it werviced three times in the last n6 months, by two different repairmen, and it works for awhile, then starts backnup again. Any suggestions?
  • Sewing Machines Master
  • 11,444 Answers
Usually, the first thing to try when a machine skips stitches is install a brand new needle. Also, be sure you are using the right type of needle for the fabric and thread you are using, ie ball point needle for knits, sharp needle for wovens, leather needle for thick fabrics/denim/leather... Needles do wear out with use, so changing needles frequently could be helpful. (Needles are the least expensive solution to most sewing problems!)
You can also try removing the upper thread. ALWAYS raise the presser foot and rethread from the beginning. Verify the thread path is correct.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
If the problem continues, it could very well be something within your machine that has not been appropriately addressed by the technicians.
Posted on Dec 29, 2016
Hi. Just bought janome400e. Having trouble with skipped stitches from 1st use. Tried thee different threads. Three different stabilisers .different fabrics. All same. Just skips a side of lettering
Try a brand new needle. If that doesn't help, then it's possible your machine needs some professional adjustment. It should still be covered under warranty.
Oct 07, 2017 | Sewing Machines
Okay, you've tried a lot of things. The question is this: is the thread snapping (where abouts in the path), or is it shredding at the needle? Here are a few more:
Remove the top thread, ALWAYS RAISE the presser foot, and rethread from the beginning.
Try different thread--perhaps a polyester thread like Isacord or Aurafil. (AVOID old or bargain bin thread.)
Try a different kind of needle (brand new needle!)--like a top-stitch, microtex, or embroidery. The top stitch needle has a larger scarf that will better protect the thread if shredding is the issue. (I use a special bobbin case that I've increased the tension for Isacord thread and I use the same thread in top and bobbin.) I also decrease the top tension a tad so the bobbin thread will not pull to the top. You may need to install brand-new needles several times on one quilt when they get dull.
Usually an 80 or 90 needle will work for FMQ through a fabric/batting sandwich.
Check that the needle's eye is the appropriate size for the thread (also a cause of shredding thread).
Set the upper tension at the midway point perhaps a bit looser for FMQ (this tension will probably need to be tweaked for your particular machine due to wear and age).
Use an FMQ foot and drop the feed dogs. A Supreme Slider (avlb on the internet) is very helpful in helping move the quilt while doing FMQ.
Work at a moderate but steady pace. I find a faster speed while FMQ gets me into spots I can't get out of, overlapping stitches, or outside the quilt edge.
FWIW, I still get some skipped stitches with FMQ. Usually, it happens when I move the fabric too fast, especially around a curve. I have a tendency of speeding up while going around a curve that will cause skipped stitches or eyelashing.
I'm also wondering if there is something to do with the fabric and/or batting you are is it Batik? Batik is very tightly woven and presents some particular challenges. The type of batting could be more dense, making it harder for the needle to penetrate the sandwich. Also, pulling or stretching the fabric can cause skipped stitches.
Basic Maintenance Tension Skipped Stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
If you see no improvement in your machine's stitching, you may want to have it serviced.
Apr 28, 2017 | Juki Sewing Machines
What is the rght tension for The Elna Contessa 410 sewing machine?
Every machine is different, so a "right" tension will vary. The factory standard tension setting is the midway point between high & low number...BUT that needs to be tweaked per your machine.
Skipped stitches? Be sure to use a brand new needle and a needle that is compatible with the thread and fabric you are sewing. (Replacing an old needle is the most common and least expensive fix for a lot of machine problems.)
Optimal tension is when the upper and bobbin threads meet in the middle of the fabric.
Feb 24, 2017 | Elna Sewing Machines
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
Jan 03, 2017 | Sewing Machines
Skipping Stitches My Singer Confidence machine is skipping stitches. I've cleaned the feed dogs and the stitch hook, changed needles three times, changed thread, adjusted the tension, etc.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Oct 07, 2013 | Sewing Machines
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
