Question about Exercise & Fitness
I have a Trojan runx treatmill showing LS and the belt is not running. What can cause this?
  • 6,694 Answers
If you wish to get some details treadmill servcie ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Dec 30, 2016
Testimonial: "I have eliminated the sensor, not that. Maybe the board, but what item on it please?"
  • Marius Scheepers
    Marius Scheepers Dec 30, 2016
Can you fit a Toyota runx 1.8 engine into a Toyota runx 1.4 body?
I would think so.they were both offered in that platform.
Aug 08, 2017 | Toyota Cars & Trucks
My Toyota runx is showing two arrows pointing each other ,what does it mean
Is it this one? If so, it is a tyre pressure signal, check the pressure of all tyres, one or more might be low.
Oct 13, 2014 | 2005 Toyota RunX 160i
I have it all set up..programmed a work out...it starts to work..but the tread itself that you walk on wont run..what do I do?
From the User manual....here
http://servicedocuments.com/pdfs/_0005_SOLE/_0005_SOLE_01_Treadmills/003_OwnersManuals/2010_2011_SOLE/F63_F65_OM_810.pdf
'1.If the belt moves, but stops after a short time and
thedisplay shows "LS", run calibration. (on next page)
2.If you press start and the belt never moves, then
the display shows LS, contact service.
Sep 14, 2014 | Sole Fitness F63 Treadmill
My trojan runx treadmill switches on, but wont run the motor, and error code LS or L5 is display, please advice on the problem
Check the speed sensor and its position. If its ok the the problem is with motor driver board .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Aug 09, 2013 | Exercise & Fitness
Does a 2003 toyota runx 1 6 rsi have a timing belt or a timing chain
I like to know my 2003 runx rsi is it using timing chain or Cambelt?
May 20, 2013 | Cars & Trucks
Speeds up and slows down
Dear Sir:
Please adjust the sensor speed for the main motor. Of course I am recommending Very Strong to RUN the software calibration for easy diagnose and troubleshooting.
Otherwise see my personal TIPS, for diagnosee
Trouble.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Mar 06, 2012 | Nordic Track NordicTrack A2550 PRO...
My landice 8700 programable is showing an L5 error and does not run how do i replace the switch that is bad with this treamill it only has an up and down button for more or less speed
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Mar 14, 2011 | Exercise & Fitness
",.exe" (comma.exe) causing a problem
Its your OS affected by virus..
Mar 04, 2008 | Computers & Internet
Exercise & Fitness Logo
50 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
