WHAT IS THE BASIC PROBLEM IF ERROR CODE E000711-0001 COMES EVERY TIME
Sharp photocopy machine showing error code Sc 542
SC 542 Basically the machine is telling you that the fuser did not reach its target temperature in a specified amount of time. In normal circumstances this code will appear if the thermistor is not maintained or replace periodically or in abnormal circumstance the heat lamp blew. This is a Service Tech reset code. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won't come ready until the prior error condition is cleared. basically you will have to care a service tech to clear it
Aug 03, 2015 | Sharp Office Equipment & Supplies
Where can i purchase a code reader
Go to Autozone,they will test if for free and tell you why your light is on.
Jul 20, 2015 | Cars & Trucks
Toyaota Camry 1994 engine won't start, Engine light on
I would check for fuel,(pressure and injector pulse), spark, and compression, before checking any codes. Lack of any of these basics can result in codes, and then you waste alot of time chasing a symptom, instead of the actual problem.If more people followed basic diagnostics, which always come back to these three basics, rather than chasing codes first,they would find no starts much more quickly.
Nov 14, 2011 | 1994 Toyota Camry
I purchased the HP officejet 4500 all in one. The message "fatal error" comes up while installing. I have business Vista. What do I do? Thanks. Lisa
some errors usually include a four-digit numbered code. if there is, please let me know. I also need to know the exact error message. where do you see the error message? on the computer or printer? PLEASE TAKE NOTE THE EXACT ERROR MESSAGE AND LET ME KNOW.
for the mean time, you can use the printer without troubleshooting the error by just installing the basic driver. the product will still print as usual however the product might not have its full functionality. steps in installing the basic driver: restart the HP software installation then select the "express" or "minimal" installation option instead of the "full recommended" installation option. Then follow the on-screen instruction to complete the installation.
Jul 26, 2011 | Office Equipment & Supplies
One beep paus paus paus paus one beep
This is the BIOS diagnostic beep code - meaning it tries to signal a problem.
Look for the motherboard type and download the diagnostic manual to read what this beep code means.
If not available - remove all RAM memory and try again. It should come up with the error "No RAM memory installed". If nothing the error is more serious and prevents the BIOS to execute basic functions. If it does prompt no RAM - then reinsert RAM one at a time. First try one then the other RAM module.
Jun 26, 2011 | Computers & Internet
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
I have a 2004 Honda civic that basically drops down to 5 mph after driving it for about an hour. The engine light will come on and then after a couple of hours its fine again to drive. It doesn't...
The check engine light comes ON,when there is error code stored in the car computer. to get car scanned at diagnosis center to get error codes, At diagnosis center you will receive the error code.As per the error code it will detect the exact faulty part in the car due to which the problem is occurring.For more help :--- at www.autozone.com its absolutely free to get car scanned. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | 2004 Honda Accord
Cant connection to internet but ssid in and do not connection come's up with error code 51330
The error code basically means it cannot establish a connection to the network, like it can't even acquire an IP address.
Aug 26, 2010 | Nintendo Wii Console
Geting code L 1 unit will not do any thing
Sound like your exposure lamp.
see if it comes on or move when you turn it on
Feb 17, 2010 | Sharp AL-1641CS Laser Digital Copier
The tv sound works all the time when turned on but occasionally the video either does not come on or goes of while watching it.
It is usually a vertical deflection circuit problem. Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Press MENU button. If a small horizontal line appears at the center of the screen, you have lost vertical sweep on your TV. The protection circuit shuts down the picture to protect the tubes from burning a line across them. The intermittent problem may indicate a loose solder. Try resoldering the vertical output IC. The IC along with the B+ feed resistor back in the sweep power supply is most probably bad or has a loose solder.
  3. Press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  4. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "24", the LED will flash 2 times, pauses, then flashes 4 times. The error code is repeated a total of 5 times. Error 24 indicates a vertical deflection circuit failure.
Please let me know the code you'll and I'll tell you where the problem lies and how to fix it.
Dec 02, 2009 | Mitsubishi WS-55859 55" Rear Projection...
22 people viewed this question
jasbo
jasbo
