Question about Refrigerators
We are faceing the problem it is working after one or two lot of ice cubes one Red warning is blinking and the machine is not working after reset the machine it will work and after one lot
peyton32034
  • 410 Answers
SOURCE: Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Posted on Jan 07, 2008
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
You have a better chance of finding out that the problem is a broken moduele. The fingers that grab the ice and rotate it out they should be resting at the 2 oclock posotion. If stuck in any other posotion its broken. It's expensive but not hard to do. If you had a bad soloniod you would either have a frozen tube or a block of ice at the top
Posted on Sep 01, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore 106.56542400 No ice, red lite blinking
Many people claim that raising the freezer temperature and using a hair dryer to defrost the ice maker will solve the problem. As for the blinking light I believe that is part of the ice maker sensor to tell if ice storage is full or not. Here is a link to the troubleshooting forum. Thanks, Sea Breeze
http://www.thriftyfun.com/tf50663056.tip.html
Posted on Mar 21, 2009
  • 744 Answers
SOURCE: kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Posted on Apr 08, 2009
SOURCE: Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Posted on Oct 14, 2009
My PT Model IM-600 US ice maker makes cubes but continues to freeze on the ouside of the cube tray blo th cubes from falling into the bucketwhat is wrong.
cubes set too large
Adjusting the Ice Cube Size: 1. Press and hold the "Adjust" button for approximately 3 seconds until the Green Indicator starts blinking, release the button. The unit is now in Ice Adjustment mode. 2a. Press the "CLEAN" button to decrease ice cube size. The Red Indicator will flash as you lower in size and will blink when you have reached the smallest possible setting. 2b. Press the "MODE" button to increase ice cube size. The Yellow Indicator will flash as you increase the size and will blink when you reached the largest possible setting. After 10 seconds without any operation, the unit will return to the previous mode. NOTE: • During the ice adjustment mode, if the "ICE FULL", "ICE MAKING" and "ICE HARVEST" LED's all blink simultaneously, this means setting is at the regular (middle) size. • When the machine is in the cleaning stage or ice full stage, the ice size cannot be adjusted.
Dec 04, 2017 | Refrigerators
Status light solid red, with blinking.diagnostic blank wont reset
Push and hold the off button for 4 secs then freeze button but chances are itll happen again until problem is corrected
Jul 15, 2015 | Scotsman CU1526SA-1A 150 Lb Self-Contained...
How to reset?
Turn machine off and back on. but if machine is locking its self out then there is a problem. needs to be fixed
Aug 01, 2014 | Scotsman CU1526SA-1A 150 Lb Self-Contained...
Why Scotsman CM3 ice machine shows diagnostics water problem?
should you have any questions, Thanks John Tripp Appliance 911
First let's look through the different service manuals. CM3 Water level sense diagnosticsDOWNLOAD
Head Pressure Control Kit - CM3DOWNLOAD
Reduce Air in CM3 ModelsDOWNLOAD
Replacement of the CM3 controllerDOWNLOAD
Service Handbook to 2007 - CM/CM3DOWNLOAD . I am here should you have any questions, Thanks John Tripp Appliance 911
May 15, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why does the the light blink on the red ice cube logo on the scotsman ice machine?
That means it is not freezing pull front cover and then you can reed the error code and if you will give me the code i can help you with it.
May 13, 2014 | Scotsman Kitchen Appliances - Others
Stops cycling intermittantly
Any advisory lights on, e.g. bin full? Clean all sensors and make sure dump valve isn't letting water gradually drain out
Apr 04, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Mv 450 scotsman ice machine
Remove the front panel to the ice maker. There should be a control panel that will give you some more info on the fault. I am guessing that you are dealing with a short freeze cycle, thin ice, or harvest error.
May 13, 2013 | Scotsman Cooled Modular Contour Cuber Air...
My scotsman model 506as 1f, serial no. 06021320015994. Was running fine until i had it sent in to a local shop for routine check up during the normal winter down time for the machine. When i started using...
Have you pulled the cover off so you can see the code it is giving really need to know it. sounds like either low charge or hot gas valve not opening during harvest. I really need the code to be able to help you out.
Jul 07, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
