Question about Boating
How to change a water impellor for 150 hp Mercury Saltwater EFI motor
captainjeffq
  • 52 Answers
SOURCE: I have a 2000 Mercury efi saltwater engine 250hp
Sounds like a problem with your injector or injector sensors. One of the nice things about the EFI`s are the ability to hook up a diagnostic unit to the motor and then a tech at a merc dealership would be able to tell you exactly which sensor or injector is the problem
Posted on Apr 14, 2009
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Posted on Jun 23, 2009
muffteck
  • 202 Answers
SOURCE: changed the ignition switch on 150 EFI mercury Outboard
just take the old one off and put the new one on just like you took the old one off
Posted on Mar 27, 2010
SOURCE: 4 beep alarm - Mercury 150 efi outboard
hi,
when the engine is running there is a repeated 4 beep alarm every 5 to 10 min. i have talked to several repair shops and they are unsure of the problem. what is the proper solution to fixing this alarm?
Posted on Apr 29, 2010
goldbill
  • 184 Answers
SOURCE: I have a mercury 9.8 outboard that I have changed
The constant ticking sound may be a bad piston from the last time it got hot. This is not good. Check the compression to test for piston damage. If you have a bad piston, you will find the bad water flow while solving the piston problem. You may have a piece of old impeller stuck in one of the little channels some where.
Posted on Aug 05, 2012
Looking for a 2016 tracker targa V 18 combo with a 150 HP murcury 4 stroke outboard engine owners manual
Manual is in the first link
Mercury 150 FourStroke Manual
https://dmna.ny.gov/nynm/manuals/Mercury_150_FourStroke_Manual.pdf
RCD-H-2 Rev 4. 150 HP 4-stroke (3.0L) hp. OP401000 or. 1B227000. RCD-H-2 Rev 4. Essential requirements. Standards. Other normative document/ method ... Owner's manual. This declaration of conformity is issued under the sole responsibility of the manufacturer. I declare on behalf of the engine manufacturer that the ...
Owner's Resources ' Mercury Marine
https://www.mercurymarine.com/en/au/service-and-support/owners-resources/ The major consideration in preparing your outboard for storage is to protect it from rust, corrosion and damage caused by freezing of trapped water. Outboard Storage tips ... Mercury Authorised Dealers have the expertise and training to handle all of your engine maintenance service and needs. Engine Maintenance.
FourStroke 150 hp ' Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/150-hp/ The specifications displayed here may not be indicative of the entire engine family; click on the "See All Models and Specs" link to view the specs in detail. ... Perfect for Repower. The compact, lightweight design of the Mercury® 150hp FourStroke engine fits most transoms, including those with narrow engine wells and tight ...
Outboard Care ' Mercury Marine
https://www.mercurymarine.com/en/ca/landing/outboard-care/ Step-by-step videos to help you maintain your 150 hp FourStroke. Flushing; Oil change ... This helpful how-to video shows you how ensure your outboard motor is maintained for peak performance. Here are step-by-step ... FourStroke engine. For more information, please consult your Mercury Marine owner's manual.
150 HP Mercury 4 stroke outboard engine owners manual Google Search
Dec 06, 2017 | HP Boating
I have a 1995 Mercury 150 hp EFI outboard. Coming in on last fishing trip the alarm and flashing light came on for high heat/low oil.
sounds like perhaps the oil injection pump failed . last one of these we just added oil to the gas and continued using it .
Aug 22, 2015 | Mercury Cars & Trucks
What indicates bad reed valves?
check the impellor ! which outboard motor do you have ?
Sep 14, 2014 | Seloc Mercury Outboard Engine Repair...
Why won't my mercury marine engine not restart after running for 30 or 40 min.
is it cooling ok ? run on hose and check engine block and exhaust plate cool ! water inlets clear and impellor good condition ? compressions all over 100psi ? carbs clean ?
Jul 23, 2014 | Clymer Mercury/Mariner 75-225 HP 4-Stroke...
Water pump
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
May 14, 2013 | Seloc Mercury Outboard Engine Repair...
Mercuryoutboardmotor oil leeking from vent
if you mean the water intake on gearbox then the oil seal bellow the impellor housing has failed and needs replacing b4 the gearbox siezes due to water gettin in and not enough oil in it !
Dec 22, 2012 | Seloc Mercury Outboard Engine Repair...
89 150 HP mercury has no spark
Hello Wendy,
Check The Kill Switch Is In on The Control Box,
Apr 19, 2012 | Light Outboard Motor Boat Bass Fishing...
Hi,I am looking for an online manual for an 85 hp mercury outboard engine,I need to replace the water pump
i have service manual for MERCURY IN LINE 75-150 HP-it covers all however my scanner printer down at present so unable to scan to lappy to be able to email at prez-hopefully this week-waiting on my computer man!
Oct 03, 2009 | Light Outboard Motor Boat Bass Fishing...
I have a 2000 Mercury efi saltwater engine 250hp that is using well over a gallon of gas per mile-have changed all filters,high end fuel pump,strator and plugs-it seems to surge some at low speed and tops...
Mar 09, 2009 | Boating
Boating Logo
54 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
