Question about DeLonghi Heating & Cooling
Heater cuts out after few hours
Delonghi calor gas heater. Lights and runs OK but cuts out after a few hours running
  • 6 Answers
SOURCE: I have a Delonghi SRI gas heater and it lights but
if the other guys solution doesnt work, go and get your heater serviced, as i had the same problem with mine and as it turns out it was just dust or something in it, think its only about $30 or $40 for a service and its recommended that lpg appliances are serviced anually anyways
Posted on Jul 21, 2009
heatman101
  • 43501 Answers
SOURCE: Please help! Our draft inducer on our gas water
You are OKAY!!!
If the inducer connot run the gas valve will not turn on.
You will be fine till morning the way you are.
Just be sitting down when they tell you the price of a new inducer...
Heatman101
Posted on Jan 20, 2010
  • 2597 Answers
SOURCE: calor gas heater pilot going out
clean pilot and burner , if no help change thermocouple
Posted on Sep 29, 2010
  • 90 Answers
SOURCE: i have a blueflame calor gas heater and the flame
in some gas heaters they cut air flow to burner to get yellow flame chack air mixture on burner not blocked
Posted on Nov 16, 2010
  • 26 Answers
SOURCE: My Delonghi Quattro Plus Calor gas heater will not
the gas valve needs replacing
Posted on Dec 09, 2010
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
I have a DeLonghi DNC65 dessicant dehumidifier about 4years ol. It runs for about 2-3minutes then the alarm light comes on and then it switches off. It is operating in a room which is 15 deg. C. Is this...
Ignore the first comment, Desiccant dehumidifiers do not have Freon, or a compressor...
The warning light coming on after a few minutes could be one of a few things (but probably most likely due to overheating or the detection of something not right in the unit operation. Most likely faults include:
1) failure of main fan motor (this would cause eventual overheat)
2) failure of heater blower motor (this would cause an overheat)
3) clogged desiccant wheel (restricting air flow and causing overheat)
Generally the warning lights only come on if an overheat occurs, If the heater has failed these units usually continue to run, albeit cold, and with no water being extracted.
Another culprit could be the water level cut of switch being faulty.
Feb 05, 2014 | Dehumidifiers
My heater runs for about 10 minutes then the flame cuts out and can't be turned on again till it cools down for half an hour...
Hi.
Replace the flame sensor, if that does not fix the problem, check the thermostats, if it cuts off in ten minutes and then restarts when cooling down, then it is either flame sensor or thermostats.
Sep 24, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have a blueflame calor gas heater and the flame is mostly yellow
it sounds like the burner could do with cleaning bust in the burner
Jan 02, 2010 | Heating & Cooling
Water heater doesn't keep running
Sounds like youo have a problematic gas valve. But I would get a gasfitter to replace it. Not for the amatuer.
Nov 20, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
1998 Dodge Ram 4X4 Pickup
Try disconnecting the battery (both terminals and let set for a few hours) with ALL the accessorries on lights-heater-radio etc. This will draw all power from your system, then recconnect battery, it's worth a try even if it doesn't solve your problem. Bill
Nov 07, 2008 | 1998 Dodge Ram 1500 4WD
Daily cost to operate
electric is billed at so many cents per kilowatt hour. a kilowatt hour is 1000 watts per hour. if your heater is rated at 3000 watts, running it for one hour will consume 3 kilowatts of energy at whatever your utility charges per kilowatt. if the amount on your bill is .026 per Kw it'll be 2.6 cents per hour.
Nov 19, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Heating & Cooling Logo
32 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
