Question about HP Officejet 5610 All-In-One InkJet Printer
Hi I'm not able to fax from pc or scan HP5610
Hi I'm not able to fax from pc or scan with HP5610. It worked perfectly last week. Had a bit of a powr surge could this be the problem?
  • admin122 Jul 22, 2009
    I can copy and fax manually and I can print from my pc, but when I try to scan or fax straight from my pc, it's a no go.
  • Michael Grey
    Michael Grey May 11, 2010
    Can you copy? If so it may be cables. Yes power surges can produce crazy results.
  • 21 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd5
Posted on Sep 06, 2009
After XP re-install, hp5610 scanner function fails
Reinstall the drivers ... making sure you have the latest driver from HP for your XP operating system.
Mar 03, 2010 | HP Officejet 5610 All-In-One InkJet...
When press # and 9 key while turning power on, the hp5610 should perform a full reset, however the "power on", "fax", "copy", "fax", "scan" and "!" all flash at the same time. How do I correct?
You can't. A reset is a #6. A #9 resets the NVM - the NVM is the firmware that makes the printer function. If you have reset the NVM there is no way to bring it back again unfortunately. It should only be used by HP in their repair department when they are seeking to replace the firmware components.
Feb 21, 2010 | HP Officejet 5610 All-In-One InkJet...
Power went out last week. Can't print. The jobs
OK try this Remove Power Cord from Printer, remove USB cable from PC. Reboot PC. Wait 10 mins, then connect, the Power again to printer. Turn OFF PC. While OFF plug in the USB cable TO any other USB other than the one used before. Turn PC ON. After a bit you should hopefully have a working printer. If that doesn't work, Unplug USB, reboot & then using your DVD re-install it all again.
Feb 15, 2010 | HP Photosmart C7280 Printer
We can't send fax from computer to HP5610
hi,
djiu9o14
Mar 23, 2009 | HP Officejet 5610 All-In-One InkJet...
MS vista drivers for HP5610
Hey,
if you mean the all in one printer hp 5610 then they are here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=441125&
Let me know if you need anything else.
Thanks,
Ekse
Jan 12, 2009 | HP Refurb HP ScanJet 5550c 48-Bit USB...
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
Lexmark 8300 print/scan/fax
There are sensors in the document feeder that detect the width and length of the paper being copied or faxed. Try getting a can of compressed air and go nuts blowing all the dust out of the feeder, if you spray everything you can get to, you will probably blow clean the sensors. Just an educated guess.
Good luck,
Printdoctor
Jun 19, 2008 | Lexmark X8350 All-In-One InkJet Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
145 people viewed this question
Seeker5211
Seeker5211
