Question about Boating
150 hp mercury outboard - Boating
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at
Posted on Jun 16, 2009
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Posted on Sep 20, 2009
  • 7 Answers
SOURCE: I have a 1978 mercury outboard 150 HP motor that
For the DIY boater it could be a number of possibilities - fouled plugs, old fuel, improper air fuel mixture or dirt in the carburetor.
Pull the plugs and check the color of the ceramic. Light tan is good. Dark and oily is an indication of misfiring, fouling and too rich oil or improper air mixture. Make a note of which plug came from which cylinder. If they're all about the same color (dark) replace them all. Properly set the electrode gap and install the plugs.
You could try spraying the intake with carb cleaner like "Gum Out"
to clean out the carbs too.
Drain and clean out the sediment bowl of the carb(s) test again.
If cleaning sdoesn't take care of the problem then you need to Reference a Mercury marine manual for initial air screw mixture settings, ie: air screw location and how many turns out are recommended.
Air fuel mix is adjusted by a screw on each carb. No more than a 1/4 to 1/2 turn should be made at a time. Test again.
Also when you store the motor for the season, get some "Gas Stabilizer" for the fuel tank. Mix the recommended amount in a full tank of fuel, run the motor for several minutes. This step will put the stabilized fuel into the carbs for storage.
Hope this helps.
Posted on Oct 05, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
  • 202 Answers
SOURCE: changed the ignition switch on 150 EFI mercury Outboard
just take the old one off and put the new one on just like you took the old one off
Posted on Mar 27, 2010
Looking for a 2016 tracker targa V 18 combo with a 150 HP murcury 4 stroke outboard engine owners manual
Manual is in the first link
Mercury 150 FourStroke Manual
RCD-H-2 Rev 4. 150 HP 4-stroke (3.0L) hp. OP401000 or. 1B227000. RCD-H-2 Rev 4. Essential requirements. Standards. Other normative document/ method ... Owner's manual. This declaration of conformity is issued under the sole responsibility of the manufacturer. I declare on behalf of the engine manufacturer that the ...
Owner's Resources ' Mercury Marine The major consideration in preparing your outboard for storage is to protect it from rust, corrosion and damage caused by freezing of trapped water. Outboard Storage tips ... Mercury Authorised Dealers have the expertise and training to handle all of your engine maintenance service and needs. Engine Maintenance.
FourStroke 150 hp ' Mercury Marine The specifications displayed here may not be indicative of the entire engine family; click on the "See All Models and Specs" link to view the specs in detail. ... Perfect for Repower. The compact, lightweight design of the Mercury® 150hp FourStroke engine fits most transoms, including those with narrow engine wells and tight ...
Outboard Care ' Mercury Marine Step-by-step videos to help you maintain your 150 hp FourStroke. Flushing; Oil change ... This helpful how-to video shows you how ensure your outboard motor is maintained for peak performance. Here are step-by-step ... FourStroke engine. For more information, please consult your Mercury Marine owner's manual.
150 HP Mercury 4 stroke outboard engine owners manual Google Search
Dec 06, 2017 | HP Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
What is ratio per gallon for mercury 150 v6
Hi Daniel!
Oil mix is 50:1 (Quicksilver recommended. Go figure!)
Here's a link to your service manual if you need it.
Boatinfo Mercury Service Manual for 135 150 175 200 hp
Sep 09, 2014 | Raymarine St6002 Smartpilot Hydraulic...
Why won't my mercury optimax 150 outboard start?
your owners manual should tell you what the beep code means.or call a dealer and ask them.
Jun 08, 2014 | Boating
Hi,I am looking for an online manual for an 85 hp mercury outboard engine,I need to replace the water pump
i have service manual for MERCURY IN LINE 75-150 HP-it covers all however my scanner printer down at present so unable to scan to lappy to be able to email at prez-hopefully this week-waiting on my computer man!
Oct 03, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
51 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
