Question about Lands Phones
1635+3 no power for month. Now can't get dial tone. ' check tel line ' in window. Line to house OK. Individual. Batteries OK.what is the problem
GetFaxing
  • 143 Answers
SOURCE: No Dial tone using Symantec Winfax Pro 10 on Windows 98
We're WinFax support experts and this usually isn't a WinFax specific problem.
Make sure you have proper drivers for Win98 and your modem. Some Conexent (SOFT) modems will allow the installation of incorrect drivers, causing all dialing functions to fail. (NO DIAL TONE/NO CARRIER/ NO Incoming RING detection)
Check your modem via Hyperterminal (or another terminal program)
http://service1.symantec.com/SUPPORT/faxprod.nsf/docid/2001040612202004
Posted on May 28, 2009
SOURCE: no dial tone and "line in use " message
Try the simple things first. Try a different phone. In my case, I had the phone company check - outside was fine. After two hours my phone worked. I figured out what happened in my case. Both phones were dead (battery). I think one died with the phone off the hook. once the phones were fully charged, the phone worked.
Posted on Mar 29, 2010
consultel1
  • 860 Answers
SOURCE: My phone says check Tel Line
Sounds like your telephone line might be dead. If you have a gray or tan telephone box on the outside of your house you can plug your phone in there to test the line. If you get dialtone then thrers a problem in your house wiring, if you don't get dial tone then the line is dead and you need to conact your telco provider.
Posted on Apr 14, 2010
  • 25 Answers
SOURCE: My phone screen says check
First be sure you have dial tone at the jack. Use a corded phone to do this with. If you do have dial tone then be sure you have ac at the outlet that the transformer is plugged in to. If there is no dial tone at the jack...go to your interface box outside and check for dial tone there....if none call the phone company. If you do have dial tone then you need to check your wires to the jack...or have the phone company do it for you. If you don't have ac at the outlet....check your breaker box or have an electrician check for you.
Posted on Nov 07, 2010
  • 4 Answers
SOURCE: Handset displays "Line in Use" no dialing tone and
I can't get dial tone either. Let me know if you find a solution please.
Posted on Jan 27, 2011
All phones are plugged in and operating but i get a busy signal on all in talk mode
I assumed when you say all phones are operating means there's power and are charging.
1. There could be some phones that are loading the Tel line. Disconnect all phones and plug it one by one while checking the dial tone. If all phones gives busy tone, there coulb be a problem in the Trunk line or the Tel Company line.
2. There could be a short or resistance in the line. Check the connection in junction box between your house and the Tel Company cable.
3. If you have an analog Tel set, you can check the dial tone directly from Tel Company cable that comes in to your house.
I hope this helps.
Best Regards.
Sep 01, 2015 | Panasonic KX-TGEA20 Additional Digital...
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
No Dial Tone from BT Diverse 7110 Single
Check that the volume on the handset is turned up, also replace the batteries or put in non-rechargeable ones to get the phone working at full capacity. If bought from Amazon you should be guaranteed for a year, not a month!
Mar 03, 2014 | BT Diverse 7110 Plus Cordless Phone - DECT...
No dialing
see if the tel line is in the black plug. and see if you got a dial tone. if not test line whit other phone. if no tone. fone your provider.
Dec 19, 2011 | Samsung SF-5100 Plain Paper Laser Fax
There is No Dial Tone?
First check the line with a normal telephone. Do you have a dial tone on it? can you make and receive a call on it? If you do then make sure that the line lead to the fax is in the "LINE" socket and not the "TEL" socket. If all ok then the NCU/LIU board in the fax is faulty
Aug 04, 2011 | Brother BRTPPF4750E...
We are having problems receiving faxes but printing is fine we do not seem to have a ringtone signal
First make sure dial tone form wall is working, just plug in a hand set. If no dial tone, call phone company. If dial tone then make sure line is plugged from wall into fax port that says Line not TEL. Can you send faxes ok?
Apr 04, 2011 | Brother Office Equipment & Supplies
Apr 14, 2010 | Uniden DECT 6.0 Cordless Telephone...
My fax machine doesnt have a dial tone, how can i fix it. its plug in the socket and in the back of the modeum.
Make sure your tel line is OK by connecting the line to a telephone first. Connect the tel line to the socket labelled LINE. If there's still no dial tone, change the line card.
Dec 13, 2009 | Brother FAX-575 Plain Paper Thermal
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
No loop current
Check the line cable. Try inserting that line to another telephone unit. And if there's still no dial tone the problem is on the line itself. You should call your line provider. But if the line is ok, check the LIU connectors if it is inserted correctly. It the connectors are ok, then the possible problem is on the tel. line circuit on its mainboard.
Sep 13, 2006 | Philips PPF-531 Plain Paper Thermal...
Lands Phones Logo
35 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
