Screen has libes down it - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 23,210 Answers
Libes? Faulty screen.
Posted on Dec 29, 2016
Do I need to oil an Elna 6003Q sewing machine?
Yes, in the middle of the bobbin case there may be a little hole with a wick below it where a drop of oil can be placed. Much of the internals are now self lubricating or designed for the tech to libe during the recommended annual service
Jun 30, 2014 | Elna Quilter's Dream 6003Q
There are 2 ports on the front,right side of the motor. One is vaccuum Port, what is the second one on the left side of it?
If ots the same size then its probably a emissions recirculation libe that recycles your exhaust. Follow the line and what it goes to, that will give you a better idea
Jun 06, 2014 | 1991 Toyota Camry
Flx3220f a tv some libes appear
The problem post of yours' haven't enough details to post a solution. Please provide more details.If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.
May 06, 2013 | Televison & Video
Own a 2001 Kia Sportage which spews gasoline out when refueling. also tends to go dead when driving down highway.
-Check breath line (vapor line), it might be bend. Tha's why it spill gas when refill.
Q: What is breath line and where is it...?
A: It's a small tube line above the filler line that along with the filler libe to the tank.
-You mean it will die when you try to press more gas...?
-If so. Possible need new spark plug.
-Check and test TPS (trottle position sensor) Must be within specification
Check mass air flow sensor & Clean. Careful do not damege.
mai
Apr 03, 2013 | 2001 Kia Sportage
How can i openline my sgh t-239
you can try codes to openline your samsung SGH-T239 through codes. you can get the codes from Wickedunlock.com
Nov 23, 2011 | Cell Phones
My pressures low
Low water volume will cause low pressure. Check for any obstructions in the suction libe and/or minor leaks that will cause the pump to **** air. If everything checks out, make sure the water is actually flowing thru the sand. If you suspect the water is bypassing thru the multi-port valve or a tunnel in the sand: pour a cup of flour in the skimmer, if you see it return thru the returns, you have your verification.
Jun 17, 2011 | Hayward SAND FILTER, PRO SERIES
Driving down road stopped at stop light and motor died. started it back up and put it back in gear (C6 auto transmission) would not go! absolutely no prior problems. no slipping hard shifting or...
There is a governor in the transmission,look on the side of trans,and there is a bubble shaped cup,this comes off,this is the governor pull it out and disasemble and clean real good.A peice of trash is stuck in there somewhere.Also,chang e the fluid and filter,and refill with dextron 3 atf alonf with libe gaurd additive,This additive is good for valve bodies and governors.If a valve in the valve boddy is stuck,this will unstick it.You can find this additive at napa auto parts.
Sep 21, 2009 | 1981 Ford Bronco
Lines on Photo
CCD FAILURE !
Just Call Sony they will do it FREE OF CHARGE ! ask them about BAD CCD !
it is a known manufac fault and all are doing it FREE !
Pls rate me WELL
Jul 16, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Computers & Internet Logo
David Payne
David Payne
