The programme light will not come on. We just bought it yesterday.The only light is the 6h delay
What is "delay wash" & how is it operated?
If you're washing machine is equipped with Delay wash.The delay start feature allows you to determine when you want the next wash programme to start. This is particularly advantageous if you want to use night time electricity tariffs or if the programme needs to be finished at a certain time, for instance when you come home from work. You can postpone the start of a programme by up to 24 hours. The display also indicates when the current programme will finish.
Aug 04, 2017 | Washing Machines
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Sep 16, 2015 | Electrolux Dishwashers
4h and 6h delay lights on. Door not opening
Call the manufacture tech support line or Google it on line and see what info comes up put in the model make of washing machine
Sep 01, 2015 | Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Zanussi TCE 7127 W, lights on, makes normal noise to start with, then no drum rotation, does this 3 times then buzzing (5 buzzes then a delay) starts, and 'end of programme' light comes on and stays...
5 beeps on the programme finished light means the motors knackered apparently, found that info elsewhere on the web. Done this to me today (and it's done it before as well, so i bought an extended warranty when the chance came fortunately). Time to get your guarantee or your wallet out i'm afraid.
Aug 19, 2010 | Zanussi TD4112W Electric Dryer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
