Question about Air Purifiers
Where can I get an alpine ozone generator plug-in module 21-80414-5
I need to know what this is and where I can get one. Living Air XL 15s.
That part is the ozone generator control board in an Alpine xl-15.
Contact the manufacturer: https://alpineairproducts.com/
Aug 31, 2016 | Air Air Purifiers
I have the Alpine Living Air machine - the green light does not come on just the amber one. I don't smell any ozone odor. Cleaned the plates but not sure if they have to be installed in any special...
How long have you owned machine? Plates need to be replaced periodically to be effective and to generate ozone. Depends on usage but at least every one-two years. They run about $15 a piece. I can get you some.
Jul 07, 2011 | Alpine Air XL-15 Air Purifier
Where can I find a ozone control for the XL-15? The part # is 21-80414-5, Phase-1.
i contacted Living air about this and they replied back stating that you can not buy this that you have to send the unit in for repair. Sounds like a rip-off to have to pay to ship it off just to have someone to plug in a new module that takes all but 1 minute.
Dec 22, 2010 | Alpine Air XL-15 Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Ozone output stopped
I am not familiar with your particular model. I can give you a generic type answer.
In these units there is a high voltage generator module. This module can fail, and therefore no ozone will be produced. It is possible that the power source that drives the module has also failed.
If you get in touch with the manufacture, maybe they can sell you spare parts, or at least inform you about how you can get the unit serviced.
As for my own opinion, when considering the age of the unit I would consider replacing it with a new model. The cost of servicing your unit may approach that of a new one which will have a warranty and higher reliability.
Jerry G.
May 15, 2009 | Alpine Air XL-15 Air Purifier
The ozone generator quit working. What is the problem and where can I get parts ?
You can pull off the rear filter, pull the ozone plates, defeat the safety interlock, turn the unit on, and place a screw driver (holding the plastic handle) one one of the ozone bars, and try to make an arc between the screwdriver and the other bar.
If you get an arc, the ozone plates are dirty. Clean well with a brush and sudsy ammonia. If no arc, either the hv transformer is bad, the main circuit board is bad, or the ozone control is bad.
There's one other thing you can check: The two wires that connect to the ozone bars can arc to the chassis sometimes. You can inspect the insulation on those wires to make sure it is intact.
May 12, 2009 | Eagle Advantage Alpine Air Purifiers Eagle...
Alpine Air Living Air XL15 not producing Ozone or Deodorizing. New plates
Confirm that the appropriate sections of the circuitry are powered up and drawing power; check the interlock switch action; toss it back to the maker because the Hi-V transformer or ladder circuit or sense or hold caps were (if testing proves) never quite functional.
Dec 03, 2007 | Alpine Air XL-15 Air Purifier
Air Purifiers Logo
159 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
